Key Stuck (really bad) 4th Gen
Old Sep 17, 2003 | 04:47 PM
Phire's Avatar
Default Key Stuck (really bad) 4th Gen
Ok so my key has been getting stuck in the ignition (4th gen) for some time now, and it was very aggravating. Well tonight upon a cold start it was stuck and STUPIDLY I forced it, and I'm pretty sure I bent something because now it will not come out at all, and the car barely turns off (very hard to get it to 'off')
How much should a new switch run and how do I install it? Is it worth going to junkyard for?
Old Sep 17, 2003 | 06:11 PM
Phire's Avatar
Default Re: Key Stuck (really bad) 4th Gen (Phire)
Nm I got it out, but I still wanna replace the switch it is very worn out/messed up
Old Sep 18, 2003 | 08:39 AM
Kavehman's Avatar
Did you try sparing some lubricant down the key cylinder ? That may solve your problem.....
Old Sep 18, 2003 | 09:03 AM
RUBZERK's Avatar
Default Re: Key Stuck (Kavehman)
I had that same problem & i fixed it by getting a new key made.
your key may be getting locked in due to wear.
Try a new key first.
Old Sep 18, 2003 | 10:03 AM
Broman78's Avatar
Default Re: Key Stuck (RUBZERK)
or use a pencil to write on the key which will work as a lubricant. I don't think you want to use a liquid lube.
Old Sep 18, 2003 | 10:38 AM
Phire's Avatar
No I really want replace it, I pretty much broke it. It is in 2 pieces now, the middle is moving independantly from the outer ring....
Dekorum
10
Sep 17, 2018 05:29 AM
shytdoode
May 7, 2009 01:31 AM
UK CIVIC B16A2
13
Jun 28, 2003 10:13 AM
