What kind of Hi-flow cat?!?! Exhaust Guru needed.
Old Sep 17, 2003 | 10:26 AM
NirVTEC's Avatar
Default What kind of Hi-flow cat?!?! Exhaust Guru needed.
I am having my current system revamped with a Magnaflow muffler and custom bent piping.
My OEM cat is original and I want to replace it.
What brands are out there? Which are actually good?
Would it be worth it to buy a 2.5" cat into 2.5" piping. I have been told that the Greddy collector is 2.25" and it would be worthless to use 2.5" piping.
It has also been mentioned to me that I could do 2.5" cat into 3" piping!
This system will be run with the below setup---VVVVV
Thanks in advance,
clint
Old Sep 17, 2003 | 10:34 AM
Padawan's Avatar
Darth ModerVader
Default Re: What kind of Hi-flow cat?!?! Exhaust Guru needed. (NirVTECn2o)
If you plan on keeping the Greddy header, I would go with a 2.25" Carsound cat. mated to a 2.25" mandrel-bent exhaust. Just be sure that the "custom bent piping" that you mention in your post is going to be mandrel-bent, not crush.
Old Sep 17, 2003 | 10:49 AM
NirVTEC's Avatar
Default Re: What kind of Hi-flow cat?!?! Exhaust Guru needed. (Padawan)
I found CATCO and CARSOUND on ebay for ~$50 shipped.
I just spoke with one of our techs, and he suggested using a Magnaflow resonator off the cat into custom mandrel into a Magnaflow!
Sound good???
Is it just not worth going with 2.5"???
Worthless because of 2.5 collector on Greddy?
Thanks again!
Old Sep 17, 2003 | 10:54 AM
mmuller's Avatar
Mad Scientist
you could just get 2.5 piping so if you wanna upgrade your header later on you already got the exhaust
Old Sep 17, 2003 | 11:42 AM
piscorpio's Avatar
Just curious because I am sort of local to you, but where are you getting the work done?
Old Sep 17, 2003 | 12:02 PM
NirVTEC's Avatar
Default Re: What kind of Hi-flow cat?!?! Exhaust Guru needed. (piscorpio)
I am having the work done at CarX on Ogden Ave in Westmont. 1 of my Techs knows someone there.
Greddy header into Carsound or Catco cat into Magnaflow resonator into Magnaflow muffler with dual 3" tips.
The only header I know of with the 2.5" collector is the MUGEN.
Whats up with SMSP?
InvaderTrax
Jul 30, 2009 02:02 PM
93HatchCali
Nov 17, 2003 09:18 PM
neilff
10
Jun 1, 2003 01:39 PM
FredoSP
Feb 23, 2003 08:55 PM
