Got code 41, O2 Sensor Heater, how can i correct
Old Sep 16, 2003 | 05:37 PM
1BadCvC's Avatar
Default Got code 41, O2 Sensor Heater, how can i correct
Where can i find wiring schematics to track this wire, im guessing, back to my cpu?
Would that be how i fix this code?
Old Sep 16, 2003 | 08:43 PM
BluLude's Avatar
Default Re: Got code 41, O2 Sensor Heater, how can i correct (1BadCvC)
if there arent broken wires and or improper wiring replace the 02 sensor
Old Sep 17, 2003 | 03:41 AM
EE_Chris's Avatar
You need a multi-meter....otherwise your shotgunning it.
Disconnect the O2 from the engine wiring harness. Measure the resistance between the 2 black wires. It should be in the 17-30ohm range...if not, your only option is to replace it.
Old Sep 23, 2003 | 07:27 AM
2camsaam's Avatar
Default Re: Got code 41, O2 Sensor Heater, how can i correct (EE_Chris)
I am getting a code 41 also.
I was initially getting a code 1 w/ the original O2 sensor in my JDM B16a w/ P30 ECU.
I swapped the O2 sensor for the one out of my original motor which was working fine in the D16z6 and P28.
Check engine light went out, car idled for about 10 minutes, I then drove it up the street and then about a mile down the street, the check engine light came back on.
I get code 41 now instead of code # 1. What is causing this?
Old Sep 23, 2003 | 07:58 AM
1bad-eg's Avatar
Default Re: Got code 41, O2 Sensor Heater, how can i correct (BluLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BluLude &raquo;</TD></TR><TR><TD CLASS="quote">if there arent broken wires and or improper wiring replace the 02 sensor</TD></TR></TABLE>
Old Oct 5, 2003 | 10:35 PM
importimage's Avatar
Default Re: Got code 41, O2 Sensor Heater, how can i correct (1bad-eg)
Is a code 1 usually requiring just a new O2?
kcrxxx
Aug 1, 2007 12:47 PM
slim689
Apr 19, 2007 10:55 AM
dustinsterk
Dec 31, 2003 09:27 AM
2camsaam
14
Sep 24, 2003 01:20 PM
VTEC-DA
Sep 2, 2003 04:39 AM
