code 23 on obd0 pw0 ECU
Old Sep 16, 2003 | 05:26 PM
shadowstylz's Avatar
Default code 23 on obd0 pw0 ECU
what is it?
Old Sep 16, 2003 | 05:27 PM
Default Re: code 23 on obd0 pw0 ECU (shadowstylz)
check engine light comes on after I rev it allittle like soon as I start it in the morning no code, soon as i put it in first and drive it out of neighborhood light comes on.
Old Sep 16, 2003 | 06:04 PM
StorminMatt's Avatar
Code 23 = knock sensor.
Old Sep 16, 2003 | 06:13 PM
SC0TT's Avatar
Good luck trying to get rid of it. Mine is doing the same thing. Ive been trying for a week now. Supposedly splicing a ground into the wire will eliminate but it doesnt.
I guess i'll have the ecu chipped.
Old Sep 16, 2003 | 06:32 PM
Default Re: (SC0TT)
what will you havce the ecu chipped, for? no knock sensor?
Old Sep 16, 2003 | 07:09 PM
zCivic's Avatar
Default Re: (shadowstylz)
I've ran mine for about 600 miles with the knock sensor grounded on the thermo housing no codes. Make sure its a good ground and free of paint etc.....You can also get a Rom that eliminates the knock sensor..Mugen usually does but I believe hyperducktuning.com would be able to tell you if other also can be removed. Another option is get a 1k ohm resistor and ground that inline with the wire to the ECU (i've never tested this one)
Old Sep 16, 2003 | 07:13 PM
Default Re: (zCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">I've ran mine for about 600 miles with the knock sensor grounded on the thermo housing no codes. Make sure its a good ground and free of paint etc.....You can also get a Rom that eliminates the knock sensor..Mugen usually does but I believe hyperducktuning.com would be able to tell you if other also can be removed. Another option is get a 1k ohm resistor and ground that inline with the wire to the ECU (i've never tested this one)</TD></TR></TABLE>
Do you know if anybody has a write up on how to ground it Im not to good with electronics but would love to do this to eliminate that god forsaken(scarey sometimes, orange light lol (cel)
Old Sep 17, 2003 | 03:57 AM
zCivic's Avatar
do you have it grounded right now?? If not on the thermo housing where the other engine harness grounds go. Get a 18-22 Ring terminal and put in on the end where the knock sensor wire went and put it with the other grounds. If want to ground it some where else. Get same ring terminal, scrape the paint of where you want to ground it. Get a self tapping screw and run it thru the terminal.....
Old Sep 17, 2003 | 06:05 AM
coyote's Avatar
same problem here . when i get the loot i am sending my ecu out to be chipped usally around 150and the speed limiter can be removed while you are at it .
acclude-vtec
Jan 2, 2006 11:00 AM
Phatch99
Jul 15, 2004 10:27 AM
THE94GSR
Jun 25, 2004 05:07 AM
roadawg
Feb 11, 2004 01:10 PM
TRhatchCRAP
Aug 27, 2003 07:01 AM
