Accord H22 fuel problem
Old Sep 16, 2003 | 03:44 PM
HybridAccord's Avatar
Default Accord H22 fuel problem
hi I have a h22 swapped into my 5th gen accord.. i have had recent fuel probs.. i have been running very lean.. i got a fuel press reg.. that didnt help.. diff injectors and fuel pump.. but then again i am still running lean my fuel press is at 40psi at idle and 50 when accelerated. .. but when i sit and idle for a little while.. my air/fuel guage creeps up all the way to rich.. but when i take it out to drive.. it never hits rich at all.. could i have a bad O2 sensor? or what else can be my prob.. please let me know what you think
Old Sep 16, 2003 | 04:20 PM
LCDeuce's Avatar
Default Re: Accord H22 fuel problem (HybridAccord)
unless you have a wideband o2 sensor your A/F gauge is just going to be a light show.
Old Sep 16, 2003 | 04:25 PM
Default Re: Accord H22 fuel problem (limeaccord)
i have a regular phantom autometer A/F guage.. there has to be some reason why it is doing so.. when i idle for a little while it will creep up slowly to last bar on rich.. but when i drive or idle in gear.. it will be last bar on lean or maybe not even light up on the guage.. no light show effect ever took place.. when i floor my car.. i dont even hit rich like it is suppose to..
Old Sep 16, 2003 | 06:34 PM
LCDeuce's Avatar
does your car bog? how does it idle?
Old Sep 18, 2003 | 07:37 AM
my car idles really rich.. after a few mins.. but then once i take it to drive it will show really lean..
Old Sep 18, 2003 | 07:47 AM
KTeller8's Avatar
cause autometer is a POS
you cant really tell by the little lights. thats far from 100% accurate.. i think that A/F light gauge is a waste of money but thats my thoughts...
on the other hand h22 naturally run rich and 40psi isnt lean at all. so i dont see how you would fall lean ??
Old Sep 18, 2003 | 01:51 PM
H22AJSPEC's Avatar
I am having the same problem have you checked your plugs are they white brown or black on the ends? Mine are white as hell and have done every thing to fix it and still nothing what ecu are you running?
Old Sep 18, 2003 | 01:53 PM
iam7head's Avatar
Default Re: Accord H22 fuel problem (H22AJSPEC)
have it tuned, is the fuel pressure low? pump's dying? fuel filter?
accord stock is about 38 psi at idle
Old Sep 18, 2003 | 02:00 PM
Default Re: Accord H22 fuel problem (iam7head)
fuel pressure at idle is 40psi and above idle is about 50.. i have a new fuel pump and fuel regulator.. my next thing is probably the fuel filter.. it is pretty old.. so i am going to change taht and see if it helps.. wut all efffects could a filter have on the fuel?
Old Sep 19, 2003 | 12:23 AM
CityHunt3r's Avatar
how in da world do u check fuel pressure? psi?
Old Sep 19, 2003 | 07:10 AM
v4lu3s's Avatar
RTFM
i will put money on nothing being wrong until you pull your plugs and tell us what color the tips are.
those a/f gauges are worthless. the stock o2 sensor cannot read very much at all. it is a switched sensor meanig that it can tell that its lean when its beyond stoichiometric and its rich when below stoich.
its does not have the capability of saying how far off from perfect it is, all it can do is say High or Low....
Old Sep 19, 2003 | 11:38 AM
Default Re: (v4lu3s)
my plugs were black when i pulled one out today.. so does this mean im running rich?
Old Sep 19, 2003 | 05:23 PM
fizzbob7's Avatar
Default Re: (HybridAccord)
"my plugs were black when i pulled one out today.. so does this mean im running rich?"
yep....those types of gauges are so inaccurate that they aren't worth what you give for them.....get rid of it or just ignore it..seriously........if you have the stock p13, then i'm sure you won't be lean...they're too rich from the factory.....
Old Sep 20, 2003 | 08:25 PM
fastaccord94lx's Avatar
Default Re: (CityHunt3r)
Fuel pressure gauge. Very easy install.
Old Sep 21, 2003 | 10:22 AM
Ryu's Avatar
Ryu
What ECU are you using?
BB6-213
Feb 17, 2011 07:39 AM
13secondmonster
May 14, 2004 07:23 AM
HybridAccord
Nov 17, 2003 04:35 AM
B_1_8_hatch
Apr 28, 2003 05:21 PM
twin pp
Dec 4, 2002 05:32 AM
