Questions about Swapping motor please help blew mine last night!
I have a 00 ex civic manual with D16Y8 and want to know how hard and the cost is going to be for a b16a2 swap and what all parts i am going to need to do so and if anyone knows someone selling a b16 swap. blew my d16y8 up last night rod right through my block last night so kind of screwed at the moment and need lots of help. if you could leeave your feedback here thanks. or maybe i should just try rebuilding my d16y8 again but need parts quick
For a B16 swap you will need:
- B series shift linkage
- B16 motor (obviously)
- P2T ECU
- B series axles and half shaft
- B series hydraulic tranny
I would recommend re-using the EX harness to plug into your shock tower harness, unless of course you receive a US B16A2 swap from any 99-00 Civic Si, then the harnesses will clip right up and no wiring is necessary. It is 100% plug and play and bolt in.
As for 91tegrals, you have one strange sig my friend.
- P2T ECU
You could find a complete swap at a number of locations. The swap should come with motor, tranny, ecu, shift linkage, axles, and engine mounts. You could probably find a B16A for about 2300-2800 depending on the year, miles, and type.
You could start by checking:
hmotorsonline.com
importautosalvage.com
jdmshit.com
for pricing on the swaps that they have. I'd also, run a search on engine swaps or check the classifieds. Good luck
hmotorsonline.com
jdmshit.com
I would just find someone either selling or giving away a D-series short block, and take your time to find a B16 cheap. Unless you get lucky and find one soon but realisticly your probably going to get stuck waiting a long time for shipping and end up paying alot.
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
i dont think he will regret it especially since hes use to driving a dseries..a b16 is a great motor to work with..especailly for the price difference and availability of a gsr..and with the price difference spend some of the cash on the b16 and turn it into a gsr killer!
DomaniEM1
Feb 13, 2017 06:27 PM
HarosGSRek
Sep 18, 2015 06:25 AM
