AC line has hole in it.
Well a month ago I installed a new radiator because the original one was leaking.
Now the clip that connected the AC fan to the radiator poped off and rubbed a hole through the metal line running to the top of the AC compressor. All the freon leaked out.
Can I just buy the metal connector and connect the line somehow or do I have to buy a entire new line?
I havn't had time to take it to a shop and ask about it.
Should I buy a freon refill kit? or just let a shop refill it? shop will probably rip me off.
Thanks guys.
Thanks guys.
a new line is under 50.00 bucks new
and a junkyard should charge even less
so just replace it and fill it up yourself
make sure you use the lubricant before the r134a
