Increasing compression ratio
Old Aug 21, 2001 | 09:53 PM
Islander's Avatar
New User
Default Increasing compression ratio
I would like to know how I can increase my compression ratio on my H22A1 engine from 9.0:1 to 10.0:1. My engine was build with forged pistons and rods for turbo use, but I would like to run NA again, but I don't want to rebuild the engine.
Old Aug 21, 2001 | 11:23 PM
sgT's Avatar
sgT
Default Re: Increasing compression ratio (Islander)
rebuild the engine.
Old Aug 22, 2001 | 12:29 PM
kahren's Avatar
sell your engine buy a diff one
Old Aug 22, 2001 | 03:09 PM
dustin's Avatar
Default Re: Increasing compression ratio (kahren)
Rebuild the engine to 10.0:1 and keep the turbo.... lots of power to be found.
Oh yeah, get rid of your EFI PMS, that is why your turbo setup is no fun. The EFI PMS sucks (I used to think it was good...no). Get a hondata.
Dustin
Old Aug 22, 2001 | 09:26 PM
Islander's Avatar
New User
Default Re: Increasing compression ratio (dustin)
What about a thinner head gasket? Do they have any that would increase compression by one point?
Old Aug 23, 2001 | 04:36 AM
Dave421's Avatar
It would be virtually impossible to increase cr by a full point without doing new pistons. Rebuild or keep the turbo.
Old Aug 23, 2001 | 10:59 AM
bigTom's Avatar
Default Re: Increasing compression ratio (Dave421)
id stay with the stock head gasket and either rebuild the motor or get a new one... actually... just rip out your pistons and put new ones in... if the cylinders are still looking healthy... u could just swap them out
Old Aug 23, 2001 | 12:55 PM
EVOCELICA's Avatar
New User
Default Re: Increasing compression ratio (ek9t)
you could pull the head off reshape the cumbustion chamber and mill the **** out of the head. It will be hard to pull a whole point of compression, it could be done.
Old Aug 23, 2001 | 12:59 PM
spyder's Avatar
New User
Pardon my ignorance...but what is an EFI PMS?
Old Aug 23, 2001 | 09:53 PM
dustin's Avatar
Default Re: Increasing compression ratio (spyder)
It is a piggyback fuel computer. It intercepts the pulsewidth sent to the injectors and the ignition timing signal to let you tune things. The main issue is that it is piggy back and is constantly fighting against the stock ECU.
Dustin
Old Aug 24, 2001 | 11:26 AM
spyder's Avatar
New User
Thanks Dustin, you're living up to your title!
Old Aug 24, 2001 | 02:24 PM
dustin's Avatar
heheh
BCHelton
Feb 8, 2011 07:49 PM
JAMSiR
May 26, 2010 08:24 AM
b18c5boy
Nov 13, 2007 04:30 AM
toooslow
Jun 26, 2003 05:35 PM
151 Proof
Mar 30, 2003 07:34 AM
