Ignition timing and temp.
Old Sep 16, 2003 | 06:57 AM
SOFLSOL's Avatar
Default Ignition timing and temp.
Does retarding timing cause increased engine temp? Im wondering if once I go back to base timing with my FI setup and boost timing master instead of 5 degrees retard at the distributor. If I will be hotter or colder. I vaguely remember back when I knew nothing about cars when I retarded my timing and the engine temp increased so I figured I'd ask.
Old Sep 16, 2003 | 12:53 PM
SOFLSOL's Avatar
Default Re: Ignition timing and temp. (SOFLSOL)
ttt
Old Sep 16, 2003 | 01:44 PM
TraKtioN's Avatar
I would say colder if you retard it since the peak pressure wont be happening at exactly TDC anymore. I wouldnt worry about hot or cold, just use the right octane with around 12:1 A/F ratio to keep temps down.
beocop
Dec 15, 2016 09:05 AM
RACEPAK
Engine Management and Tuning
Aug 4, 2015 09:30 AM
wytechoppin
Feb 28, 2007 05:52 AM
CRXLST
Oct 28, 2004 07:52 AM
