GSR block with B16a head?
Old Sep 16, 2003 | 05:41 AM
7rrivera7's Avatar
Default GSR block with B16a head?
Can I do this or do I need a GSR head? What are the pros and cons? What about a type r block and B16 head?
Thanks!
Old Sep 16, 2003 | 07:24 AM
jcda6's Avatar
Default Re: GSR block with B16a head? (7rrivera7)
Pros:
More torque
Main girdle
B16 flow characteristics are better at high rpms
Cons:
slightly weaker R:S ratio
lower CR with B16 head
A Type R engine is basically a B18C block (with factory strengthened internals and higher compression pistons) mated with a B16 head. I'm running this setup currently and love it.
-Jeff C.
Old Sep 16, 2003 | 09:43 AM
7rrivera7's Avatar
Anyone else?
Old Sep 16, 2003 | 10:31 AM
denshu's Avatar
throw in some p30 pistons and have higher compression then the type r
or the civic type r pistons
Old Sep 16, 2003 | 11:36 AM
skunked's Avatar
Default Re: GSR block with B16a head? (denshu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denshu &raquo;</TD></TR><TR><TD CLASS="quote">throw in some p30 pistons and have higher compression then the type r
or the civic type r pistons</TD></TR></TABLE>
Just to clarify, the P30's will yield higher compression than the ITR pistons but not the CTR pistons. ITR pistons in a B18C with a B16 head is a very strong reliable street setup.
Old Sep 17, 2003 | 05:27 AM
7rrivera7's Avatar
Default Re: GSR block with B16a head? (skunked)
Any B18C or specifically C1 (gsr) or C5 (type r)?
Old Sep 17, 2003 | 09:58 AM
jeremy.'s Avatar
i'm running the same setup but with jdm itr pistons
sonny0330
Oct 22, 2007 06:28 PM
EJ1_203
10
Sep 28, 2007 04:28 PM
blackjackEG
20
Jan 3, 2007 07:09 AM
DOHC VTEC EG
Apr 28, 2004 06:23 PM
