JDM b16 compatible with 98+ ITR tranny?
Old Sep 15, 2003 | 06:26 PM
playAho's Avatar
Default JDM b16 compatible with 98+ ITR tranny?
I was wondering if the 98+ JDM ITR tranny and the USDM ITR tranny are the same?
will either of these trannys work on my JDM b16 it is a 94 if that helps.
also I have an ACT clutch and ZEX flywheel are these compatible with the ITR tranny JDM or USDM?
thanks for you time!!
Old Sep 15, 2003 | 06:51 PM
Eyewitness's Avatar
Default Re: JDM b16 compatible with 98+ ITR tranny? (playAho)
JDM and USDM trannies have a diff 4th and 5th gear...there close though....and YES it will work
Old Sep 16, 2003 | 12:05 AM
Timmay's Avatar
Default Re: JDM b16 compatible with 98+ ITR tranny? (Eyewitness)
doesnt the JDM ITR tranny have different axels or is that just on the hub?
Old Sep 16, 2003 | 05:34 AM
playAho's Avatar
the jdm ITR tranny has the shorter 4th and 5th gears right?
thanks for your time!!
this might be a dumb (?) but is there any problems with OBD1 and OBD2? I don't think there it but I want to make shure.
thanks for you time!!!
Old Sep 16, 2003 | 07:29 PM
playAho's Avatar
bump help need to fix my car.
Old Sep 17, 2003 | 08:53 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playAho &raquo;</TD></TR><TR><TD CLASS="quote">the jdm ITR tranny has the shorter 4th and 5th gears right?
</TD></TR></TABLE> longer. no problem. not dumb, no difference in OBD. no prob.
Old Sep 19, 2003 | 06:44 PM
playAho's Avatar
Default Re: JDM b16 compatible with 98+ ITR tranny? (owen_the_soyboy)
so just to be positive!! the jdm ITR 98+ tranny will fit and work on my 94 b16 right?
p.s. Im also curios about what timmay asked about thy axles
Old Sep 20, 2003 | 01:05 PM
inspyral's Avatar
Yes, it will work.
98-spec JDM ITR axles are larger on the hub end, the tranny end is the same.
Old Sep 21, 2003 | 08:32 AM
playAho's Avatar
Default Re: (inspyral)
so you are saying I can just use the axles that I have and it will work fine?
Old Sep 21, 2003 | 10:32 AM
inspyral's Avatar
Yes.
Old Sep 21, 2003 | 12:52 PM
playAho's Avatar
thanks!!!!!!!!!!!!
Old Oct 2, 2003 | 07:28 AM
EG6 SiRII's Avatar
New User
Default Re: (playAho)
the 98 spec JDM ITR tranny will work with your B16A, but if you're planning to leave your engine stock, you better get a CTR tranny or 96 spec ITR, since the 98 spec tranny have longer 4th and 5th gear, the B16A doesn't have enough power to push those gears, unless your engine is modified, when you shift into 4th from 3rd the engine will fall out of it's powerband. i had a JDM B16A in my EG with a Spoon tranny, that's how i know, the first 3 gears will be very good, but the rest is just...blah
Old Oct 2, 2003 | 09:07 AM
drvfast's Avatar
also itr trannys has dual syncros on there gears.
Old Oct 2, 2003 | 09:28 PM
playAho's Avatar
Default Re: (EG6 SiRII)
planning for boost will it run -k- wit just bolt ons for now?
tomlinson619
25
Dec 14, 2012 11:08 AM
Crisgo
Transmission & Drivetrain
Dec 16, 2008 06:17 AM
kcjohnnyboy
Nov 5, 2005 11:41 AM
StinkyTofu
Aug 17, 2003 05:46 AM
nY's FiNeSt
16
Jan 7, 2003 01:52 PM
