Spark and Fuel but no start...??
Old Sep 15, 2003 | 05:51 PM
g2turbo's Avatar
Default Spark and Fuel but no start...??
88 civic dx, the car cranks getting spark and fuel but will not fire. any suggestions?
Old Sep 15, 2003 | 07:45 PM
blah13's Avatar
Default Re: Spark and Fuel but no start...?? (g2turbo)
Timing, fouled plugs, bad gas, lack of compression.
Check your timing, do a compression test, and change your plugs.
Old Sep 15, 2003 | 07:47 PM
Sanj's Avatar
If ur getting spark and fuel the vehicle should start, but maybe ur getting fuel and spark at the wrong time. Check ur valve timing, possible the timing belt may have jumped time. Also I would check engine compression using a compression tester to check the mechanical condition of the engine. Check all vacuum hoses and electrical connnections. Let me know how it goes! Hope this helps! Where are u checking for spark? at the coil or spark plug wire? if u have spark at the coil, check for spark at the plug wires also. Remove spark plugs and check for fouled and flooded spark plugs, check for cracks in distributor cap causing a short to ground. I've seen a Honda civic with both spark and fuel not start, the reason was the cap had a crack in it and spark was leaking to ground before it got distributed to the rotor, this occured in wet weather. Visuallly inspected everything under the hood and look for anything that make have come loose or connectors that are corroded. Let me know how it goes! Good Luck!
Old Sep 15, 2003 | 09:58 PM
alexo49's Avatar
Default Re: (Sanj)
Same thing here...spark and fuel but no start, took it to a shop today and later on they call me and tell me i have no compression in cylinder 1,3 and 4 said most likely i bent some valves but wont know until tmw when they open her up.
What do u guys think?
Old Sep 15, 2003 | 10:08 PM
HONDADNA's Avatar
Default Re: (alexo49)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexo49 &raquo;</TD></TR><TR><TD CLASS="quote">Same thing here...spark and fuel but no start, took it to a shop today and later on they call me and tell me i have no compression in cylinder 1,3 and 4 said most likely i bent some valves but wont know until tmw when they open her up.
What do u guys think?</TD></TR></TABLE>
A tear down is not needed to confirm for bent valves. They just need to perform a leak down test. This will tell them if a valve is damaged.
Old Sep 16, 2003 | 04:22 AM
g2turbo's Avatar
Default Re: (HONDADNA)
actually this is a newer engine and i have already checked and got a different distributor, and plugs. it is very weird. the car was running great and one day went out to start it and just out of the blue no start. i traced spark all the way to the plug. im getting fuel all the way through the injectors. thanks for the replies keep em coming. thanks CHRIS
Old Sep 16, 2003 | 05:02 AM
T4eg's Avatar
Default Re: (g2turbo)
If you are getting spark and fuel. I would check the timing and make sure its not a couple teeth off. And do a Cylinder Leakdown Test. Hope this helps you
Old Sep 16, 2003 | 08:05 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">... im getting fuel all the way through the injectors.</TD></TR></TABLE>Did you check if the injectors are actually spraying? Or just that there's fuel pressure in the rail?
Old Sep 16, 2003 | 08:31 AM
Rpc07's Avatar
Default Re: (JimBlake)
check your ecu fuse and see if its blown.
Old Sep 17, 2003 | 06:24 AM
g2turbo's Avatar
Default Re: (Rpc07)
i actually check and saw the injectors firing. ill check the ecu fuse. thanks.
Old Sep 17, 2003 | 07:20 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
earlier u said u were getting fuel and spark..if it was the ecu fuse u shouldnt get any fuel or spark..sounds like timing to me....just my .02 good luck keep us posted
Old Sep 17, 2003 | 08:31 PM
sleeper4dr's Avatar
just to make sure... when you turn your key to START, you do hear the fuel pump charging for 2 seconds when your CEL comes on right?
Brandeno
May 31, 2015 08:55 AM
drb88
Honda CR-V & Element
Aug 12, 2013 02:18 PM
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
Honda Hick
Feb 28, 2005 09:20 AM
smallttocs
May 25, 2004 08:39 PM
