anyone else have a crx that leaks water from where the hydraulic arms are in the trunk?
Old Sep 15, 2003 | 05:24 PM
civicracer1993's Avatar
Default anyone else have a crx that leaks water from where the hydraulic arms are in the trunk?
it drips everytime it rains off the arms that hold the trunk open. i checked the sunroof and the tubes and no water is gettin in there .. i cannot find any where else to seal but its comin in somewhere. any ideas?
Old Sep 15, 2003 | 05:36 PM
xpsonic's Avatar
Default Re: anyone else have a crx that leaks water from where the hydraulic arms are in the trunk? (civicr
yeah same problem here also..cant find out why
Old Sep 15, 2003 | 05:59 PM
r7's Avatar
r7
is it shut fully?
Old Sep 15, 2003 | 06:37 PM
CRXracer88's Avatar
yep have the same problems with mine ........ clueless
Old Sep 15, 2003 | 06:49 PM
dankbudz11357's Avatar
Default Re: (CRXracer88)
aparently a lot of people have this problem, i just have mysterious puddles of water appear in my car, not off the arms though
Old Sep 15, 2003 | 07:25 PM
budnick's Avatar
my trunk area also fills up wit h some water no clue where from but it finds it way in
Old Sep 15, 2003 | 07:34 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (budnick)
mine was doing that and it was leaking from the rear window squirter on the roof. Just seal it up and should solve your problem
Old Sep 15, 2003 | 10:28 PM
Fobtions's Avatar
Default Re: (yebabee)
i think its probably the drain tube that are on the sunroof rails..
Old Sep 16, 2003 | 04:39 AM
Crxfanatic15's Avatar
Default Re: (Fobtions)
I dont have sunroof drain tubes or rear washer squirter and mine does the same thing everytime it rains.
Old Sep 16, 2003 | 04:47 AM
iain's Avatar
Default Re: (Crxfanatic15)
it's the hatch rubber seal thingamajig
to confirm this, open the hatch a pour a cup of water in between the boot hinges. if water drips off where the lifters attach, the seal isn't working properly
Old Sep 16, 2003 | 07:11 AM
NAsohcNovtec's Avatar
Default Re: (iain)
I havnt hade water come in that part , But if you look at the channel when the hatch is open water can come right into the tail light every time , i put a little black silcone in that corner .
Old Sep 16, 2003 | 07:57 AM
raene's Avatar
Oh, the leaky hatch joys
OK, I've had leaks from the sunroof drain tubes, the little black vents that sit above the rear hatch wall, each and every taillight, and I'm still getting water in the hatch somehow... maybe the window seals, maybe the hatch struts, maybe the hatch rubber seal, maybe the rear window squirter. I haven't figured it out yet.
The sunroof drain tubes, I removed the little black fingers that always caught crud and caused it to clog. No problems since. The little black vents I used large amounts of silicone and sealed them up all along the edges. No problems since. The taillights I'm too cheap to replace the seals on, so I used large amounts of silicone and created my own taillight seals by siliconing the seal to the taillight and then siliconing the assembly to the chassis. No problems since.
But yet... it still sometimes leaks. I'll get it this winter though!
Prudz_lude
Feb 8, 2016 11:19 AM
bad 91 teg
33
Oct 1, 2011 02:34 PM
mycrxsi89
Aug 15, 2008 04:54 PM
green91
12
Feb 1, 2006 11:00 AM
effinnwackk
10
Jul 15, 2005 05:31 AM
