Integra overheated! Now possible engine damge?
Old Sep 15, 2003 | 02:45 PM
THE GAME IS THICK's Avatar
Default Integra overheated! Now possible engine damge?
my dad was driving my car up to Reno, on the way there the car overheated because of the cheap *** replacement radiator we got from autozone was leaking from the cap area. He told me the temp. went all the way to the red then he pulled over. when he got back i ran a compression test and it was really really low. Like #1 150, #2 120, #3 120, and #4 160. Also the check engin light came on and its giving me a C.E.L. code 71 whish is a misfire in cyl. #1, i was just thinking of buying a long block with low miles and just swapping out the old one. Does anyone know where i can get a long block that will work with a 97 integra LS? I checked hmotorsonline and all the posted on their site was a 94-95 ls long block will this work or will i have a problem. Please let me know any help is appreciated
Old Sep 15, 2003 | 03:03 PM
Audi A4's Avatar
Default Re: Integra overheated! Now possible engine damge? (igotsol!)
yeah it will work, im sure he fried ur cylinder
Old Sep 15, 2003 | 04:52 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: Integra overheated! Now possible engine damge? (DRAG lll INTEGRA)
Looking at the numbers from your Compression test.... Yes, your engine is damaged. That is assuming you did the test correctly.
-Will
Old Sep 15, 2003 | 06:26 PM
maxxdout's Avatar
Default Re: Integra overheated! Now possible engine damge? (integra707)
please ensure that you performed the test correctly and didnt back the motor up. I had similar results the comp. testing my nissan and i backed it up just alittle bit, it jumped time just a few degrees, and the results were way off. Also, dont bump the motor just because. Consider machine work. Its alot cheaper if thats whats needed if things are warped and such. Just find out for sure whats going on before getting too ahead of yourself.
Old Sep 15, 2003 | 10:34 PM
Default Re: Integra overheated! Now possible engine damge? (maxxdout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxxdout &raquo;</TD></TR><TR><TD CLASS="quote">please ensure that you performed the test correctly and didnt back the motor up. I had similar results the comp. testing my nissan and i backed it up just alittle bit, it jumped time just a few degrees, and the results were way off. Also, dont bump the motor just because. Consider machine work. Its alot cheaper if thats whats needed if things are warped and such. Just find out for sure whats going on before getting too ahead of yourself. </TD></TR></TABLE>
back the engine up? i ran the same compression test procedure and i pulled 190 psi on all four cylinders in my del sol. I can get a long block for $750 but it says its for a 94-95 LS (OBD-1), would it be possible to use that engine on a 97 LS (OBD-2) what would i need to swap out from my old engine? Also does anyone else know other places where they sell LS long blocks?
Old Sep 16, 2003 | 12:25 AM
integraL's Avatar
i got code 71. misfire solution for me, was to change the wires and spark plug
Old Sep 16, 2003 | 12:33 AM
Stewie's Avatar
Default Re: Integra overheated! Now possible engine damge? (integraL)
I would rather base my decisions on a leakdown test than a compression test..
Old Sep 18, 2003 | 01:43 PM
maxxdout's Avatar
Default Re: Integra overheated! Now possible engine damge? (Mac8008)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mac8008 &raquo;</TD></TR><TR><TD CLASS="quote">I would rather base my decisions on a leakdown test than a compression test..</TD></TR></TABLE>
no doubt. A much more educating test for engine condition.
Old Sep 18, 2003 | 02:09 PM
Frito1's Avatar
Leakdown
Old Sep 18, 2003 | 02:36 PM
slo2kgsr's Avatar
Default Re: Integra overheated! Now possible engine damge? (Frito1)
over heating can lead to a warped head which would bring down compression
Rudy84
Apr 9, 2010 10:41 AM
diesel1245
Jul 14, 2006 08:56 AM
ctegsta
Aug 8, 2004 11:04 PM
projectEK9
Feb 27, 2004 03:56 AM
ChaseIntegra
Nov 11, 2002 07:08 PM
