Best way to set up my LS/Vtec
I am overseas in Iraq so I don't have time to search for this, my net time is limited. I have a 89 hatch, stripped to the bone. Now should I do a stroker kit or just do some over size pistons. Either way it is going to need new sleeves, I have Darton in mind. I have a Skunk 2 intake manifold, skunk 2 cams, well the whole head is skunk 2. I am also going to be getting a clutch and under drive pulleys. The head is soon to be on it's way to port flow. O by the way, this will be more racer than daily driver. Thanks for the help folks. As soon as I get all the info I will order the stuff so when I get home I can put it on.
Stroking aint cool man.... Bore it to a 2.0... Darton is deff the way to go... but your also gonna need pistons... IE 85 mm bore requires 85 mm pistons and so on.
So an 85MM bore would make it a 2 liter? I just want the most out of an LS-Vtec. If I go with say an 85mm with new sleeves etc etc how much of a shot can it take?
stocker2shocker91
13
Oct 17, 2007 09:33 AM
7rrivera7
Jun 29, 2007 05:52 AM
