ACT clutch $?
Old Sep 14, 2003 | 09:10 PM
96b18c's Avatar
Default ACT clutch $?
I was wondering how much the street disc and heavy duty pressure plate cost?
Does anyone know and does anyone have anything bad to say about it?
Old Sep 14, 2003 | 11:41 PM
J Gordon's Avatar
Default Re: ACT clutch $? (96b18c)
I bought mine for $389 on special from http://www.hondadriven.net, now it's $405. It took them about 9 days to ship me an "in-stock" part, so I didn't get it for more than 2 weeks from when I ordered it.
The clutch is an excellent piece. The pedal is a little stiffer than stock, and the engagement point is a little lower, but it's smoother and grabs a lot harder. You should replace the flywheel at the same time with a lightweight one, since you would probably have to get the stock one resurfaced anyway. I bought the XACT streetlite (12.5 lb) flywheel. If I could do it again I would get the prolite (8.5? lbs.) I was worried about driveability with a lightweight flywheel, but I think the car is easier to launch with the streetlite than the stock flywheel.
Old Sep 15, 2003 | 12:16 AM
SoCal ITR's Avatar
Default Re: ACT clutch $? (J Gordon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J Gordon &raquo;</TD></TR><TR><TD CLASS="quote">I bought mine for $389 on special from http://www.hondadriven.net, now it's $405. It took them about 9 days to ship me an "in-stock" part, so I didn't get it for more than 2 weeks from when I ordered it.
The clutch is an excellent piece. The pedal is a little stiffer than stock, and the engagement point is a little lower, but it's smoother and grabs a lot harder. You should replace the flywheel at the same time with a lightweight one, since you would probably have to get the stock one resurfaced anyway. I bought the XACT streetlite (12.5 lb) flywheel. If I could do it again I would get the prolite (8.5? lbs.) I was worried about driveability with a lightweight flywheel, but I think the car is easier to launch with the streetlite than the stock flywheel.</TD></TR></TABLE>
Well put, I have the HDSS with a 8.8 lb XACT flywheel and I pretty much love it. I paid about $600 for everything.
Old Sep 15, 2003 | 06:10 AM
rapid_roy's Avatar
Default Re: ACT clutch $? (SoCal ITR)
Another vote for the HDSS and ProLite, very sweet combo. I am 80 miles from break in, but so far it is much smoother and nicer to drive than stock. I don't know about launching it yet, 2 more days. I paid $525 on a groupbuy.
Cheers,
Roy
Old Sep 15, 2003 | 01:05 PM
IntEGNYC's Avatar
Default Re: ACT clutch $? (rapid_roy)
Any experience with weird vibration or scraping noises with the new clutch? I read some horror stories with Aftermarket clutches and im curious.
Old Sep 15, 2003 | 01:19 PM
J Gordon's Avatar
Default Re: ACT clutch $? (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">Any experience with weird vibration or scraping noises with the new clutch? I read some horror stories with Aftermarket clutches and im curious. </TD></TR></TABLE>
No vibrations, shaking, or scraping in the last 3000 miles. Occasionally, before everythings warmed up, I'll note a real quiet, low pitched noise kind of like opening a door with squeaky hinges that lasts all of a 1/4 second. But I don't feel it in the pedal at all.
I've never heard any horror stories about ACT clutches, though I'm sure some are out there. I've heard of much more go wrong with most other clutch brands such as Exedy or Clutchnet, though those brands still seem to have a pretty good track record. The general consensus is that ACT makes high-quality, better-and-more-durable-than-OEM equipment.
Old Sep 15, 2003 | 01:24 PM
2lowintegra's Avatar
i have an ACT HDSS in my integra.. i've had it for about 2000 miles. i love it, no chatter or anything, but i did a proper break-in.
Old Sep 15, 2003 | 01:34 PM
NeoGSR's Avatar
just make sure you get the flywheel resurface no matter what, and follow the manufacturers proper break-in and have a competent shop/friend install it.....
tweekerz
Jul 28, 2006 07:43 PM
LSTEG96
Mar 18, 2004 11:53 PM
civicracer99
Aug 25, 2003 01:32 PM
mhgleitz
Jul 16, 2003 02:16 PM
StinkyTofu
Dec 12, 2002 07:36 PM
