Easy One
Old Aug 21, 2001 | 04:46 PM
scn095's Avatar
Default Easy One
What is the metal cable for that runs from the block or rocker cover to the frame? I thouhgt it was for gounding, but that's what the (-) on the battery is for. It is to help prevent degradation of the upper radiator hose or something?
[Modified by scn095, 5:47 PM 8/21/2001]
Old Aug 21, 2001 | 04:49 PM
fixhondas's Avatar
Default Re: Easy One (scn095)
additional grounding and noise reduction
Old Aug 21, 2001 | 04:50 PM
G's Avatar
G
Default Re: Easy One (fixhondas)
You beat me to it....Answer the vtec question (fixhondas)......
Old Aug 21, 2001 | 07:31 PM
BreakStuff's Avatar
New User
Default Re: Easy One (G)
and listen when they say "noise reduction"
You wouldn't believe how much engine noise is reduced from "ground straps"
Old Aug 22, 2001 | 08:45 AM
keithv's Avatar
Default Re: Easy One (BreakStuff)
My Civic wouldn't even start without that ground strap!!!
Old Aug 22, 2001 | 02:43 PM
scn095's Avatar
Default Re: Easy One (breaka_1_9)
Thanks. The strap on my car was starting to fray, so I constructed a new one w/ plastic-coated steel cable. The thing is, the new cable is a lower gauge than the original strap. How probable is it that the new cable may be to small to handle the possible current load, and, if it fails, what may happen?
Old Aug 22, 2001 | 03:03 PM
fixhondas's Avatar
you can make your own or get one from a dealer- they are only a few bucks. I don't think I would use steel cable for wiring- it will work though. Just seems kind of ghetto to me.
Old Aug 23, 2001 | 01:55 PM
scn095's Avatar
Thanks. I check the connection between the frame and the cable every time I open my hood. It seems to be okay so far, but I'll go to the dlrshp this weekend and get a new one.
Sam
ACTION JACTION
Engine Management and Tuning
Jul 2, 2011 07:14 AM
5thgencivic
Welding / Fabrication
Apr 20, 2005 06:35 AM
Ronin150
Jun 5, 2004 04:44 AM
1BlackHatch
Audio / Security / Video
16
May 1, 2003 04:21 PM
goforbroke
Jan 18, 2003 08:47 PM
