transmission assembly
Old Sep 14, 2003 | 08:46 PM
mhgleitz's Avatar
Default transmission assembly
anyone who has taken apart their manual transmission, help. i've taken mine apart and put in a quaife diff.. now that i've put it back together, i can't get the linkage to go into reverse or 5th. i've put everything back together exactly how it came apart, but something is in a bind. the transmission is still out of the car, and i've reassembled it 7 times. anyone ever ran into this problem or know of any way to help?
Old Sep 15, 2003 | 10:41 AM
mhgleitz's Avatar
Default Re: transmission assembly (mhgleitz)
also, when i have the housing apart, i can move the gears into reverse with my hands, but when i try to use the fork to do the job, it binds.
Old Sep 16, 2003 | 10:30 AM
mhgleitz's Avatar
surely someone on this wonderful tech page can lend a helping hand
Old Sep 17, 2003 | 11:19 AM
mhgleitz's Avatar
please?
Old Sep 17, 2003 | 11:45 AM
kotetu's Avatar
Do you have a helms manual (diagrams are AWESOME for the tranny), and did you take pictures while taking it apart? it may be something is not quite right.
Transmissions are precision devices, so it's probably pretty tricky to put it back together properly.
Old Sep 17, 2003 | 12:00 PM
flyrod's Avatar
Default Re: transmission assembly (kotetu)
Hard to guess without looking at it, but it can't be too many things... Are you turning the mainshaft by hand while trying to shift it? Sometimes it won't shift by hand unless you move the syncros some. Check the 5th to reverse stop in the shift cover. Pull that cover off and try directly moving the 5th/rev shift fork. If it's binding, see if you can tell what is stopping it's travel. Check for a bent shift fork on 5th/rev. Check that the reverse idler gear moving fork is in properly and doesn't bind.
Old Sep 17, 2003 | 12:07 PM
caz245's Avatar
did you try to turn the input shaft first sometimes just rotating it will line everything up inside and let it slide into gear, other than that without seeing it I cant really help you.
Old Sep 17, 2003 | 12:49 PM
mhgleitz's Avatar
Default Re: transmission assembly (caz245)
thanks for the help guys. if i turn the gears enough it eventually goes into gear, but it seems much harder to do than it was before i took the tranny apart. shift forks look fine, reverse idler fork is fine. do you think it's possible that it is so hard to shift because it's not on the car and full of gear oil? i'd hate to put it back on and have to remove it again.
Old Sep 17, 2003 | 01:30 PM
GruvyTune's Avatar
New User
i had the same problem.
i had to open mine all the way up again only to find out i had the reverse fork below the groove in it. i think you may find the same thing if you open it again.
Old Sep 18, 2003 | 04:59 AM
mhgleitz's Avatar
Default Re: transmission assembly (GruvyTune)
are you talking about the reverse fork that goes to the idler gear? you didn't have it around the gear?
jspeccrx91
Jul 11, 2009 09:38 PM
94SuperLudeSI
Jan 22, 2008 02:21 PM
2point2
May 5, 2007 02:17 PM
JDM_SOHC
Mar 15, 2007 07:26 PM
UNKNOWN_MEMBER
Jun 15, 2005 06:30 PM
