Any Tips for a 92 Civic Dx 4 Door?
Old Sep 14, 2003 | 06:48 PM
Dx_Civic_Dx's Avatar
Default Any Tips for a 92 Civic Dx 4 Door?
I Could realy use some pointers on going about fixing a 4 door civic,,i am leaning on changeing the engine. dose any one else have any ideas .. i will be happy to hear them all. Ty
San Diego.
poison's Avatar
Default Re: Any Tips for a 92 Civic Dx 4 Door? (Dx_Civic_Dx)
The search link up on the upper right hand corner will direct you to a world of learning that`ll help you out
Old Sep 14, 2003 | 06:54 PM
Also I wanted to know if there is a way to drop a V-6 in a civic with a little mods i dont want to do a full mod job on it... just wondering, and if ther is a way which engines should i use,
Old Sep 14, 2003 | 06:56 PM
Kusai.Nihonjin.Desu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dx_Civic_Dx &raquo;</TD></TR><TR><TD CLASS="quote">Also I wanted to know if there is a way to drop a V-6 in a civic with a little mods i dont want to do a full mod job on it... just wondering, and if ther is a way which engines should i use,</TD></TR></TABLE>
That would cost a lot of money.
Old Sep 14, 2003 | 06:57 PM
poison's Avatar
V6? not happenin...
Old Sep 14, 2003 | 07:00 PM
Default Re: Any Tips for a 92 Civic Dx 4 Door? (poison)
well ty for the info. i just needed a little pointers.....ty every one
Old Sep 14, 2003 | 07:03 PM
dunkd's Avatar
yah v6 4door... thatd be hot... go take about 10g's out of the bank and goto your local shop!
Old Sep 14, 2003 | 07:04 PM
poison's Avatar
Default Re: Any Tips for a 92 Civic Dx 4 Door? (dunkd)
For a V6 going in there, that is a LOT of angle die-grinding, and a big time weaker frame rail chassis support.
don`t think it's happenin..
Old Sep 14, 2003 | 07:08 PM
BauleyCivic's Avatar
Risky Business
H22 is the "V6" for a civic
Old Sep 14, 2003 | 07:12 PM
Default Re: Any Tips for a 92 Civic Dx 4 Door? (BauleyCivic)
yea it dont look like i am dropping any v-6 in my civic ,, but it was just an idea. well if any one has any suggestions oon a good engine let me know ,, i am in thr prosses in looking doe a better engine then the stock Dx engine that i have now. so all info will help me out, ty
Old Sep 14, 2003 | 07:16 PM
dunkd's Avatar
heyyyy, stock DX isnt bad... 16.8 from mine! "dont be hattin"
Old Sep 14, 2003 | 07:17 PM
SOHC_MShue's Avatar
how much do you have to spend? If your budget is under $3000 then i would suggest getting a 92-95 civic ex engine. It is called a d16z6 and has vtec. They have 125hp stock and should give your car a nice little boost in power and won't break your check book.
Old Sep 14, 2003 | 07:19 PM
gamby's Avatar
B16A--easy
B18B--easy
B18C--easy
H22A--Trickier and pricier, but still straightforward.
Search on all of those engine codes and soak up as much info as you can. You have a long way to go in terms of learning what to do.
logjammin
Jun 18, 2012 12:39 PM
andrey320
Sep 17, 2007 05:15 PM
Rizz
Feb 7, 2007 03:33 AM
brkdwn5
20
Dec 5, 2004 10:16 AM
GdmLaz
Mar 11, 2004 11:01 PM
