fog light switch wiring
anybody have a wiring diagram for the OEM foglight switch? Theres a red wire w/ white stripe, red wire w/ yellow stripe, and a black wire.
I originally though that red w/ white was power from battery, red w/ yellow was to foglights, and black was ground... although the switch doesnt work this way.
I hooked up an ohmmeter to it, and I show a circut going from red w/ white stripe and black.
can anybody help me out?
UPDATE BELOW. I GOT SOME OF IT FIGURED OUT
Modified by Hcivic88 at 7:20 PM 9/20/2003
someone must have wired in a switch before, or know what wire goes where... If only I had a helms, i bet it probably shows it in there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic88 »</TD></TR><TR><TD CLASS="quote">I hooked up an ohmmeter to it, and I show a circut going from red w/ white stripe and black.
can anybody help me out?</TD></TR></TABLE>
I looked in the service manual for the 90/91. There isn't anything in there for fog lights.
My guess is that there is supposed to be a relay by the fogs that is tirggered by a negative pulse. I would think that the black goes to ground and the red/white goes to the relay. The red/yellow then goes to power for the light on the switch.
TEST: If you hook ground to black and the red/white and then power to the red/yellow does the light on the switch light up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">
TEST: If you hook ground to black and the red/white and then power to the red/yellow does the light on the switch light up? </TD></TR></TABLE>
hmm.. thats a theory i didnt think of....
although if that were true, wouldnt there be some sort of resistance going from red/yellow to red/white??
also, how exactly would I run a relay so that it's triggered by a negative signal, but still puts out a positive signal to the fog lights??
and about the test, im on my way to try it out right now
ok, back from test...
when i put the black to ground and...
1. red/white to power, blows a fuse
2. red/yellow to power, nothing happens, no lights turn on, no fuses blow...
I wonder if maybe the black wire isnt ground. maybe the pins were switch or something... cause when its blowing the fuse, im guessing that its going from power, right to ground. so maybe the black wire is suposed to go to the foglights, red/yellow is power, and red/white is ground...
heres a diagram of what I have now
1- red/yellow
2 - red/white
3 - empty
4 - black
This is when looking at the back of the switch, with the harness plugged in.
and I'm sure that 3 has to be empty, cause when I take the harness off, theres no pin for the harness to plug into. So its just the other 3 that could have been moved.
Modified by Hcivic88 at 8:58 PM 9/15/2003
1- red/yellow
2 - red/white
3 - empty
4 - black
<u>UPDATE</u>
well, i played around with some stuff. I picked up 10 fuses today, so I was planning on trying every wire combination that was possible. Then I got smart, I decided that I wouldnt connect the ground, since I dont need it to find out if the switch is going to work. So i kept switching the wires around till I could turn the foglights on and off with the switch. There are only 2 possible combinations to use to get the lights to turn on and off with the switch.
black(4) goes to the foglight relay, and red/white(2) goes to the power supply
or
red/white(2) goes to the foglight relay and black(4) goes to power.
Although I still cant figure out what red/yellow(1) is for, I at first thought it was the ground for the light inside the switch, but when I connect it to ground, the light still doesnt light up.
Modified by Hcivic88 at 7:21 PM 9/20/2003
or
haha, Got the same problem with my JDM fog light swith. No matter how I hook it up weather the button is pressed in or not the fogs turn on as soon as the thing is touches power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant »</TD></TR><TR><TD CLASS="quote">haha, Got the same problem with my JDM fog light swith. No matter how I hook it up weather the button is pressed in or not the fogs turn on as soon as the thing is touches power.</TD></TR></TABLE>
haha, sounds like you're having a fun time like me, lol. Sounds like your fog light switch is acting like driving lights. although if they were driving lights, there wouldnt be a switch. Atleast my switch works, just no light, lol. could even be a burnt bulb for all i know, i have no idea how to switch a bulb in it though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant »</TD></TR><TR><TD CLASS="quote">mine lights up just fine. Just doesnt do crap when you press it in and out.
and it does that no matter how you hook it up???
sounds like we have the opposite problems, haha, your switch is gone, and my light is gone.
</TD></TR></TABLE>and it does that no matter how you hook it up???
yeah, i had mine apart too, lol. its kinda weird looking... some little square thing that slides around is the switch
anyways, i finally got mine working
black was power, red/white went to foglights, and red/yellow went to ground
1- red/yellow -> ground
2 - red/white -> foglight relay
3 - empty
4 - black -> 12V power
so I have a working light up switch now
too bad you cant say the same
Modified by Hcivic88 at 8:39 AM 9/22/2003
3 - empty
Nisif
Honda CR-V & Element
12
Dec 7, 2024 11:50 PM
8valvesoffury
Feb 12, 2009 10:14 AM
