OOOOPS! help! is this bad?
Old Sep 14, 2003 | 08:42 AM
shming123's Avatar
Default OOOOPS! help! is this bad?
i was filling up the gas tank yesterday, it was locked on full blast...and the auto-off think didn't work and gas sprayed out EVERYWHERE! Right where the cap is, it was filled past the little valve that you stick the gas pump nozzle in, so i took LOTS of paper towel to absorb the excess gas... well, one of the times i did it, papertowel got through that little valve thing and like 2-3 square inches of paper towel got ripped off from that valve and fell back into the gas tank!! OOOPS! it was not that much paper towel, but still. and you know the gas station paper towel, its more like paper..........Anyways, is this bad? could it get clogged? or do you think it will just sort of disintigrate/dissolve? PLEASE HELP!
Old Sep 14, 2003 | 09:43 AM
skribblah's Avatar
Default Re: OOOOPS! help! is this bad? (shming123)
it will prollie dissolve and just sit in the gas tank. the gase sump that picks up the gas has like a sock filter over it, then that in combonation with the fuel pump, i wouldent worry about it.
Old Sep 14, 2003 | 11:34 AM
shming123's Avatar
anyone else have insight?
Old Sep 14, 2003 | 01:41 PM
Attoir's Avatar
Default Re: (shming123)
I bet you're fine. No personal experience, but I wouldn't worry.
Old Sep 14, 2003 | 02:00 PM
VTECorona's Avatar
I'm sure the gas tank sucker-up'r has some kind of mesh screen over it to prevent any kind of random foreign objects from getting sucked up.
Old Sep 14, 2003 | 03:31 PM
Gunns's Avatar
the fuel pump does have a little white bag on it that will not allow it to be sucked up. Try putting the same amount of paper towel in a sink of water and see what happens. Now amagine its gas. I wouldnt sweat it!
Kurt
Old Sep 14, 2003 | 05:45 PM
Audi RS4's Avatar
Lover
Default Re: OOOOPS! help! is this bad? (VTECorona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure the gas tank sucker-up'r has some kind of mesh screen over it to prevent any kind of random foreign objects from getting sucked up.</TD></TR></TABLE>-/
that is correct....
Old Sep 14, 2003 | 06:31 PM
blah13's Avatar
Default Re: OOOOPS! help! is this bad? (AK1200)
Not only that but you also have your fuel filter if peices get by the screen. Your ok.
Old Sep 14, 2003 | 06:51 PM
mr.beeks's Avatar
Default Re: OOOOPS! help! is this bad? (blah13)
it is easy to remove your fuel pump assembly
right underneath the back seat
since probably floating around it may be stuck to your fuel pump
redef90si
Feb 25, 2010 10:50 PM
dmckrazy45
May 26, 2006 05:15 AM
HondaHemi
Dec 3, 2005 05:51 PM
null.
Jun 22, 2005 07:03 PM
96SR-V
Apr 19, 2004 09:18 AM
