More Cooling Troubles....PLEASE HELP
Old Sep 14, 2003 | 08:29 AM
jdmsol's Avatar
Default More Cooling Troubles....PLEASE HELP
I'm still having cooling problems on my D16Z6. I've replaced the radiator, thermostat, temp. sensor and cap. The fan tests okay, but it never turns on. If I have another bad thermostat and it is not opening, could that be causing a false reading from the sensor...making the fan from turning on? Thanks in advance.
Old Sep 14, 2003 | 08:37 AM
t0p_sh0tta's Avatar
Default Re: More Cooling Troubles....PLEASE HELP (jdmsol)
Stupid question, but did you bleed the system properly? Are you running the stock sol radiator?
Old Sep 14, 2003 | 09:00 AM
jdmsol's Avatar
Default Re: More Cooling Troubles....PLEASE HELP (t0p_sh0tta)
Yes, the system has been bleed properly. It's a dual core radiator...the same as the VTEC del Sols, so yeah it's pretty much the same thing as stock.
Old Sep 14, 2003 | 09:32 AM
~~~InNeEdFoRsPeEd~~~'s Avatar
* B A N N E D *
as for the fan, might want to check the fuse and fan relay....seems like you've change just about all thats could cause overheating, but what about the water pump?....good luck
Old Sep 14, 2003 | 09:40 AM
WCI's Avatar
WCI
Default Re: More Cooling Troubles....PLEASE HELP (~~~InNeEdFoRsPeEd~~~)
Is it eating up coolant? If so it could be the head gasket. That was what my problem was.
saschmeling
Honda Civic (2006 - 2015)
Mar 30, 2017 03:26 PM
white98gs-r
Apr 5, 2009 06:51 AM
91accordwagon
Jan 16, 2005 07:28 PM
hitop
Jan 16, 2003 03:38 PM
kento
Jul 16, 2001 05:15 PM
