overheating problems?
Old Jan 16, 2005 | 06:21 AM
91accordwagon's Avatar
Default overheating problems?
I just had the radiator replaced and had the system bled before the fall of last year. About a 1.5 months ago, the lower radiator hose was leaking and had overheating problems but lately, again I have noticed that the fan would always turn on once I turned off the engine and also the temp gauge would go up to near HOT.
I am also losing quite a bit of coolant on the reservoir and have to add more of the Type 2 coolant but I have not seen any leaks so far nor puddles.
Need help to figure out the problem(s). Thanks in advance.
Old Jan 16, 2005 | 05:19 PM
jdowen2's Avatar
Default Re: overheating problems? (91accordwagon)
The cheapest route would be to have your system pressure tested. That rules out a lot of possibilities. Could also be thermostat, fan or fan relay problem.
Old Jan 16, 2005 | 07:28 PM
BaddMo2002's Avatar
Next time your fan goes on..pop the hood and make sure it's turning @ a good speed. Sometimes, when those things begin to die, the speed of the fan decreases.
loup05
Dec 11, 2008 04:43 PM
Cuda
Mar 21, 2007 11:25 PM
turbotime
Nov 14, 2005 12:45 PM
ek9si
Jun 18, 2003 04:42 AM
hitop
Jan 16, 2003 03:38 PM
