Hondata installed: Car won't idle.
Well, as few know, someone tried to steal my car 2 weeks ago, they decieded to take my VAFC instead. While also smashing my steering column badly. Steering column is back together, and i installed a honda S200B. St00pid sent me a map to use, so i burned it to the rom, and put it all in. Well, the car will start for a second, and die. You have to give it just a hint (1/8th) of throttle for it to not die, and it just runs like complete ***. What do you guys think is the problem? i checked all my wiring from when i uninstalled the VAFC, and it all seems ok. Not throwing any CEL's. anyuthing i should be looking for?
here my setup:
'90 honda Accord
Jdm h22a
DSM 450 CC injectors
Hondata s200b
P28 ECU
Car ran decent on the vafc hack...
'90 honda Accord
Jdm h22a
Hondata s200b
P28 ECU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr »</TD></TR><TR><TD CLASS="quote">its most likely the hondata map is too rich.</TD></TR></TABLE>
I'll fire up the wideband and check it out.
whoever tuned the car should have you previous map...just get a copy of it and reburn it. If you never got it tuned...then get it properly tuned on a dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster »</TD></TR><TR><TD CLASS="quote">whoever tuned the car should have you previous map...just get a copy of it and reburn it. If you never got it tuned...then get it properly tuned on a dyno.</TD></TR></TABLE>
I just need to find a decent basemap and go from there. There aren't any tuner's in Tucson, so it makes it alittle harder.
eg:R
May 29, 2006 01:51 AM
