Squeaking sound from wheel(s)...brake pad/rotor?
It's annoying as fawk. Not a constant screech but squeaks repeadetely..goes away when I step on the brakes. so do I need new brake pads or what? I'm lazy.
its a warning ... that your brake pads need to be changed.. my **** is the same right now and i hate it .. if u drive it to much it will go to the rotor eventually just change em .. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epsom salt »</TD></TR><TR><TD CLASS="quote">its a warning ... that your brake pads need to be changed.. my **** is the same right now and i hate it .. if u drive it to much it will go to the rotor eventually just change em .. good luck
If it isn't the wear indicators, then I'd recommend taking out the pads and putting some brake grease on the backs and shims.
After that, your best bet is to get new pads and rotors.
</TD></TR></TABLE>If it isn't the wear indicators, then I'd recommend taking out the pads and putting some brake grease on the backs and shims.
