OBDII-->OBDI idle question
Old Sep 13, 2003 | 09:26 PM
paradise57's Avatar
Default OBDII-->OBDI idle question
I just got a chipped p28 for my 99ex--the new ecu has a higher rev limit and a slightly different VTEC engagement point. When I first installed the ECU, everything was fine.
However, I went back to the stock P2P for a while because I had to get my car inspected, and NC is one of the states that now does OBDII testing. When I went to re-install the P28, my idle started fluctuating (when engine was cold, mostly) from about 900-1500 rpm.
When I switch back to the P2P, no problem. So my question is, what difference between OBDII and OBDI would cause an idle surge in one and nothing in the other?
I will be cleaning my IACV later next week when I do some other engine work, but wanted to see if it might be something else, esp. since one ECU works fine.
Also, I am 95% sure the p28 ecu has no problems itself.
Thanks!
Old Sep 14, 2003 | 07:00 AM
paradise57's Avatar
Default Re: OBDII-->OBDI idle question (paradise57)
bump for the morning!
Old Sep 14, 2003 | 07:24 AM
RyanEJ8's Avatar
Unplug your EVAP purge solenoid.
Old Sep 14, 2003 | 07:32 AM
paradise57's Avatar
Default Re: OBDII-->OBDI idle question (RyanCivic2000)
And that won't cause any other problems?
Thanks for the help!
Old Sep 14, 2003 | 08:07 AM
RyanEJ8's Avatar
OBDI doesn't need it. It's just an emissions control.
b16bem1
May 14, 2013 11:25 AM
crxb16a90
Engine Management and Tuning
Mar 4, 2011 02:06 PM
schwing27
21
Mar 17, 2009 08:49 AM
mikeunreal2
31
Mar 12, 2006 10:28 PM
