Fasteners for Manifold/Downpipe/Wastegate?
Old Sep 13, 2003 | 08:38 PM
Bnjmn's Avatar
Default Fasteners for Manifold/Downpipe/Wastegate?
Apparently stainless steel, which my turbo manifold is made out of, loves to expand and sheer bolts. Ideally I'll be using a stud and nut setup on the downpipe, manifold, and wastegate fasteners. What grade/material fasteners should I use? How much room should I leave for thermal expansion of the studs when drilling holes? Is grade 8 alright for the exhaust bolts? Other than using anti-seize is there anything else I should do?
Thanks
Ben
Old Sep 13, 2003 | 09:05 PM
rjardy's Avatar
Default Re: Fasteners for Manifold/Downpipe/Wastegate? (Bnjmn)
Are there no expansion slots cut into your manifold?
Rob
Old Sep 14, 2003 | 11:19 AM
Bnjmn's Avatar
Default Re: Fasteners for Manifold/Downpipe/Wastegate? (rjardy)
If they aren't there I'll be making them. I suppose I could cut slots on the downpipe flange and the wastegate flange and I'd be all set.
Any preference for bolt strength- 8.8, 10.9, stainless, etc.??
Thanks
Ben
Old Sep 14, 2003 | 11:29 AM
Jared's Avatar
I would use stainless bolts since exhaust parts love to rust because of the heat they're exposed to.
Jett_07
May 29, 2007 03:56 PM
Patron
Feb 13, 2004 08:35 AM
slooogsr
Nov 5, 2003 02:59 PM
integranator
Sep 9, 2003 08:30 AM
cajnatc
May 11, 2003 10:59 AM
