Need info on VTEC sensors ... pics?
Guest
Posts: n/a
Hey I'm gonna wire **** up while my B16's out of the car, and heres what I need to know...
I. Color of wire and spot where i can find the "VTEC Solenoid"
II. Color of wire and spot where i can find the "Knock Sensor"
III. Color of wire and spot where i can find the "VTEC Pressure Switch"
IV. Is the only thing I need to provide power to and ground the VTEC Solenoid? or the knock sensor as well?
V. OR, is there a site that says the local and wire colors of the wires I need to deal with?
THANKS in advane =D
THANKS in advane =D
what chassis/chassis harness/engine/ engine harness/ ecu?
We're not mind readers.
Also, what info are you going off of that tells you what sensors you needed to accomodate?
-PHiZ
-PHiZ
South Bay Surfer
Nov 22, 2002 11:00 PM
