VAFC question
Old Sep 13, 2003 | 07:30 AM
Akkord29's Avatar
Default VAFC question
i am gettin a code for my vtec and i heard that if the vafc is not wired properly that would cuase the problem, i have had my car tuned so i dont want to loose all my settings on my vafc but if i disconnect the harness where the two pieces of it meet would i be able to see if the vafc is causing the problems and not have my settings erased?
Old Sep 13, 2003 | 09:33 AM
fizzbob7's Avatar
Default Re: VAFC question (Akkord29)
if you can adjust your vtec crossover point, then it has to be hooked up properly
if you can't adjust it, then you have the signal wires wrong.....maybe backwards or just not connected well...the vtec wire goes to the in wire, then the out wire goes to the ecu...just checking that shouldn't hurt.....or you could always just write down your specs and reset them...not hard
Old Sep 13, 2003 | 06:19 PM
TurboBumblBee's Avatar
Default Re: VAFC question (fizzbob7)
vafc will not loose settings when they are disconnected..
Old Sep 13, 2003 | 08:28 PM
iam7head's Avatar
Default Re: VAFC question (Hybrid95CivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid95CivicEX &raquo;</TD></TR><TR><TD CLASS="quote">vafc will not loose settings when they are disconnected.. </TD></TR></TABLE>
correct, even if it's store for a month or so...personal experience
Old Sep 13, 2003 | 08:29 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizzbob7 &raquo;</TD></TR><TR><TD CLASS="quote">if you can adjust your vtec crossover point, then it has to be hooked up properly
if you can't adjust it, then you have the signal wires wrong.....maybe backwards or just not connected well...the vtec wire goes to the in wire, then the out wire goes to the ecu...just checking that shouldn't hurt.....or you could always just write down your specs and reset them...not hard</TD></TR></TABLE>
spacebar not working huh?
EK_BackHatch
12
Mar 4, 2004 02:05 AM
Shakes
Feb 26, 2004 01:39 PM
wgs0023
Feb 26, 2004 03:49 AM
MAD ITR 55
Nov 26, 2003 08:12 PM
S2KP
Oct 8, 2003 07:08 AM
