92-95 d series intake manifold.. will it fit?
Old Sep 13, 2003 | 06:23 AM
green91's Avatar
Default 92-95 d series intake manifold.. will it fit?
i may have the chance to buy a 92-95 intake manifold, fuel rail with injectors, and all sensors for a pretty good price. im wanting it to convert my DX to mpfi. with the Si ecu will it work the same as a crx/civic Si manifold? all the same sensors? thanks
Old Sep 13, 2003 | 07:30 AM
BIG RICH's Avatar
Default Re: 92-95 d series intake manifold.. will it fit? (green91)
yeah, that manifold will fit the DX head. some of the sensors are different. it will work though. you may need an Si throttle body.
Old Sep 13, 2003 | 07:36 AM
green91's Avatar
Default Re: 92-95 d series intake manifold.. will it fit? (BIG RICH)
sweet
there seems to be more 92-95 manifolds available. does anyone know which sensors are different and if i really need an Si throttle body? thanks
Old Sep 13, 2003 | 07:40 AM
BIG RICH's Avatar
I beleve the map sensor is mounted to the throttle body on the 92-95's
Old Sep 13, 2003 | 10:17 AM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">sweet
there seems to be more 92-95 manifolds available. does anyone know which sensors are different and if i really need an Si throttle body? thanks</TD></TR></TABLE>
If you use the 92-92 intake manifold (Z6) you can use the Z6 Throttle body or a Y8 throttle body or even B-series throttle bodies but you can NOT use the Si throttle body it wont fit there is a different bolt pattern for it. As for the sensors none are different but there is an extra one on the A6 that ISNT on the Z6 and one of them on the Z6 is in a different location than the A6 intake. go see the thread "Doing a mini-me swap right now!!" and there is a good explanation in there about where things go. Otherwise do a search for either Z6 intake manifold or d16z6 and you should find everything you need to know.
*EDIT* heres that thread https://honda-tech.com/zerothread?id=617785
JasonKarl
11
Apr 9, 2008 02:33 PM
xxmikexx206
Feb 2, 2006 12:56 PM
Vera
Nov 22, 2003 09:17 PM
Turbo Powa
17
Jun 18, 2002 11:31 AM
