B20/vtec into 95 hatch, do i need Engine mounts or will inserts do?
Old Sep 13, 2003 | 12:39 AM
Dragger817's Avatar
Default B20/vtec into 95 hatch, do i need Engine mounts or will inserts do?
Got a b20/vtec mildly built going into a 95 hatchy, will i need to replace the engine mounts? can i use inserts or should i swap out the engine mounts?? Can i use integra engine mounts? thanks!
Old Sep 13, 2003 | 01:30 AM
simple4012's Avatar
New User
Default Re: B20/vtec into 95 hatch, do i need Engine mounts or will inserts do? (Dragger817)
tranny mounts the same. driver side integra mount and integra rear t mount. make sure you get shift linkage yO!
Old Apr 27, 2004 | 09:39 PM
kcalb_3pe's Avatar
Default Re: B20/vtec into 95 hatch, do i need Engine mounts or will inserts do? (simple4012)
back from the dead.....anyways just wondering if this applies lsvetc inside a 92 hatch.....if so will 90-93 mounts work
Old Apr 28, 2004 | 08:11 AM
teamsol's Avatar
Default Re: B20/vtec into 95 hatch, do i need Engine mounts or will inserts do? (92whitecx)
yes you would still need the 94 and up integra mounts for an lsvtec swap
Old Apr 28, 2004 | 03:46 PM
kcalb_3pe's Avatar
Default Re: B20/vtec into 95 hatch, do i need Engine mounts or will inserts do? (teamsol)
forgot to add that it was a b18a1 block if that makes any difference???
EG6Boy702
33
Apr 27, 2009 03:55 PM
Hyoriu
Nov 28, 2008 09:32 PM
Poroshok
Jul 16, 2007 07:12 PM
infamousALLMTR
Mar 5, 2002 10:24 AM
