V-AFC tuning lag?
Old Sep 12, 2003 | 09:17 PM
satan_srv's Avatar
Default V-AFC tuning lag?
Has anyone noticed a tuning lag for the V-AFC? Like if I say +5 at 5500rpms on the high cam, does the desired effect on a/f show up right at 5500rpms? Or shortly after?
I'm just looking at my a/f graph and my dyno, going to add my +/- to the graph and fine tune it, so I just want to know if I should be compensating for a 1-30rpm lag if there is one. Thanks.
Old Sep 13, 2003 | 10:42 AM
MrTodd's Avatar
Default Re: V-AFC tuning lag? (satan_srv)
I notice a little bit of lag in the a/f ratio for a few hundred rpms one vtec hits... Not sure if it's the VAFC though, I always figured it's because of my non-vtec OBD-0 PM6 ECU.
Old Sep 13, 2003 | 11:32 AM
satan_srv's Avatar
Default Re: V-AFC tuning lag? (MrTodd)
I mean like all the time...say you did a generic 4500,5000,5500,6000,6500 for increments. Obviouly the fuel needs aren't easily applicable in only 500 rpm increments. Just looking at my a/f it's not immediately noticeable that the different fuel change is affecting the a/f ratio...I'll build in a slight anticipation factor I guess.
Just if you look at the A/F curve I've made adjustments every 500rpms so you don't see immediate changes know what I mean?
gsrx
Nov 24, 2004 02:12 PM
2lobes1engine
May 16, 2004 04:06 PM
Grimm
Sep 4, 2003 08:39 AM
bartek_b
May 11, 2003 10:03 AM
ITR 01-0840
Jan 7, 2002 04:59 PM
