Help Car died out
Old Sep 12, 2003 | 07:41 PM
Jx3069's Avatar
Default Help Car died out
I have a B16 motor and last night I swap my camshafts into gsr camshafts, I didn't adjust the valve that well and it was ticking really loud plus coolant was getting into the head for a while but it seem to have stop. Anyways at a stop sign earlier I forgot the car was still in 3rd so I tried to go but the cry died out, and it won't start back up no more. Any ideas what might be wrong?
Old Sep 13, 2003 | 01:54 PM
Turbo12acer's Avatar
you torq them to specs? loud ticking means you need to adjust valves.
Old Sep 13, 2003 | 07:30 PM
Jx3069's Avatar
Default Re: (Turbo12acer)
not yet but would that be the problem tho? Could it be my distribitor or ignition coil?
Old Sep 13, 2003 | 08:28 PM
Kamin's Avatar
Default Re: (Jx3069)
could have slipped a timing belt tooth check that first.
Old Sep 14, 2003 | 01:00 AM
Stripped Honda's Avatar
99-0104
Default Re: (Kamin)
coolant in the head???????????? by changing the cams??????????? that is a first .... check the cam timing you may have jumped timing... do you have spark???
Old Sep 14, 2003 | 01:07 AM
Jx3069's Avatar
I kno I thought that coolant thing was weird too. No spark, just swaped in my friends working distribitor still that doesn't seem to be it. I guess I'll try to check the cam timing tmw. Is there any other possible reasons?
01typer1124
Mar 16, 2009 06:49 AM
xlasianizelx
Mar 24, 2008 10:54 PM
camboMONK
10
Mar 28, 2007 06:04 PM
tteg94
Jul 9, 2004 01:10 PM
intekragsr
Mar 21, 2003 10:23 AM
