slows down w/vtec
i have a 91 accord and im still using the stock fuelpump. when it hits vtec it feels like its slowing down, is that because the stock pump cant feed enough fuel?
also, when i connected my exhaust, an apex ws, the idle was rough and sometimes stalled out. but when i ran it without the muffler, it runs ok. is the backpressure causing some sort of problem?
You are very vague describing your set-up.
First I would specify what motor you have...91 Accords didnt have VTEC.
I assume you have an H22 Swap but you dont say that anywhere so for all we know its an F series 2.2 VTEC from a 94 accord w/like 145hp.
Just a suggestion.
PS: if it IS an H22 swap I would say you prob should get the right fuel pump - the F22 fuel pump likely is not good enough (I could be wrong)
Just a suggestion.
