Heat Issues w. Darton Sleeves and/or Block Guards
Guys, I'm new here so bear with me. I did a search and didn't find much on this board, but I read somewhere that running Darton sleeves (with the built in a block guard) or having a block guard cause over-heating issues on the street, because:
1. the water jacket pathway is furher restricted and not as much water flows through.
2. the iron sleeves retain a lot more heat then the aluminum ones do.
my question is how valid is this? how do you fix this problem? Would an upgraded radiator and fan be a solution to this problem? Is anybody running sleeve or a block guard and having a problem with heat issues?
Is this on an S2000? I have Darton sleeves on my ITR and I have no overheating problems. I have a stock radiator and slimline fans. I run over 12psi of boost and see hp in ranges over 350whp with no overheating issues. The only time I have heard of some issues is with some of the civic guys running the stock single core radiators, but that is fixed using a better single core like a fluidyne or Koyo. Hope this info helps. If it is in an S2000 the stock radiator will be more than enough to provide cooling and you shouldn't have any problems.
WakeSpliter
Sep 13, 2003 04:35 PM
BlwnBlue
Jan 19, 2002 08:44 AM
