Overheating Issues w. Darton Sleeves and/or Block Guards
Old Sep 12, 2003 | 02:14 PM
WakeSpliter's Avatar
Default Overheating Issues w. Darton Sleeves and/or Block Guards
Guys, I'm new here so bear with me. I did a search and didn't find much on this board, but I read somewhere that running Darton sleeves (with the built in a block guard) or having a block guard cause over-heating issues on the street, because:
1. the water jacket pathway is furher restricted and not as much water flows through.
2. the iron sleeves retain a lot more heat then the aluminum ones do.
my question is how valid is this? how do you fix this problem? Would an upgraded radiator and fan be a solution to this problem? Is anybody running sleeve or a block guard and having a problem with heat issues?
Old Sep 12, 2003 | 07:06 PM
Default Re: Overheating Issues w. Darton Sleeves and/or Block Guards (WakeSpliter)
nobody knows anything about this??
Old Sep 12, 2003 | 07:35 PM
gitwidit's Avatar
I run an str block guard with stock sleeves and stock radiator, no overheating problems at all. 15k on the setup
Old Sep 13, 2003 | 01:35 PM
Default Re: Overheating Issues w. Darton Sleeves and/or Block Guards (GITWIDIT)
i would've thought their would be more posts....
Old Sep 13, 2003 | 01:37 PM
Boostfed's Avatar
New User
Darton sleeves here no overheating issues at all, always at a little over 1/4 on the coolant gauge no matter what.
Old Sep 13, 2003 | 04:35 PM
earl's Avatar
Default Re: Overheating Issues w. Darton Sleeves and/or Block Guards (Boostfed)
Look elsewhere for your problem. Overheating not caused by iron sleeves. Stock sleeves are not aluminum either.
Closing the deck does hinder water flow but not to the point of chronic oc=verheating
MR.johnson
Jul 18, 2012 06:44 PM
mrbsponge
17
Apr 9, 2006 05:46 PM
allmota1.8
Jun 26, 2004 03:01 PM
kaptr1d
Mar 15, 2004 04:51 PM
WakeSpliter
Honda S2000
Sep 16, 2003 11:29 AM
