Z10 Bedplate (keyword add: block girdle bed plate halo ring)
Old Sep 12, 2003 | 07:06 AM
CheezeFrog's Avatar
Default Z10 Bedplate (keyword add: block girdle bed plate halo ring)
Does anybody have any experience with the new Z10 bedplate block girdle? Looks like something similar to what they do on the K-series motors and SRT-4 motors. What do you guys think of it?
Since it appears to become an extension of the block skirt, it requires a proprietary oilpan:
Old Sep 12, 2003 | 07:10 AM
Finest's Avatar
Default Re: Z10 Bedplate (CheezeFrog)
Uhh, what's it do? heh heh j/k
Looks impressive nonetheless.
Old Sep 12, 2003 | 07:12 AM
done's Avatar
How woudl the z10 bedplate compared to a normal R block gridle..?
Old Sep 12, 2003 | 07:18 AM
boosted hybrid's Avatar
From what i have been told they are not machined 100% in tolerances. When you torque the main caps down they give an uneven distribution, thereby wearing the bearings out quicker. I would love to run one, but I havent been able to get a counter statement on what I have heard from anyone reputable.
*Edit* I am speaking of the 3 row block girdle, so quite possible this would be different.
Modified by boosted hybrid at 11:30 AM 9/12/2003
Old Sep 12, 2003 | 07:39 AM
liam821's Avatar
25 Year Member
Default Re: Z10 Bedplate (boosted hybrid)
Ive heard the same thing...
liam
Old Sep 12, 2003 | 08:05 AM
Bnjmn's Avatar
If you have this doweled for the main caps and then line honed then you should have no bearing problems. Assuming the aluminum doesn't deform at high temps.......
Ben
Old Sep 12, 2003 | 08:43 AM
ladysman's Avatar
Default Re: Z10 Bedplate (Bnjmn)
Endyn has one too.
Go here.
http://www.theoldone.com/components/block_girdle/
Old Sep 12, 2003 | 08:48 AM
Andrea's Avatar
The added cost of the line bore, and doweling is at least the cost of the girdle itself. It adds another 600-700.00 into building the bottom end. Between the cost, labor, and questionable performance gains adding one is in most cases not worth it.
Old Sep 18, 2003 | 10:45 AM
Z10ROB's Avatar
Default Re: Z10 Bedplate (50trim EK)
Endyns Girdle is not a 5 Main. Its a 3 Main COPY! of the Z10 3 MAIN
Old Sep 18, 2003 | 12:49 PM
rOby's Avatar
Default Re: Z10 Bedplate (Z10ROB)
that main uptop, the 5 pt , looks awefully familiar to a drawing i believe geoff posted. hmm
Old Sep 18, 2003 | 12:55 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Z10 Bedplate (rOby)
Me myself, I like this one,
Or check it out right here...
http://store.hybridgarage.com/...00001
Adi
Old Sep 18, 2003 | 01:04 PM
CheezeFrog's Avatar
Is the one Geoff posted a bedplate design as well? I'm kinda thinking of using one, and if there's more than one on the market, so much the better.
Old Sep 18, 2003 | 01:18 PM
FuzzyGreen's Avatar
I prefer my stock one:
Part #9.
Only $60.00 if anyone wants to see if it fits on their B series.
Old Sep 18, 2003 | 02:08 PM
HXMan's Avatar
Default Re: Z10 Bedplate (FuzzyGreen)
It does seem pretty crazy to me that D series motors come with such a good block girdle, and the B series didn't.
Maybe honda wanted to be extra careful because of the long stroke?
Old Sep 18, 2003 | 02:42 PM
Full-Race Geoff's Avatar
Default Re: Z10 Bedplate (HXMan)
that is the girdle from the b20a5 or the b21A from the 88-91 prelude, not the D series.
That motor had a long stroke and very short rod, and as a result an awful rod:stroke ratio.
Old Sep 18, 2003 | 03:59 PM
Jamison's Avatar
Default Re: Z10 Bedplate (FFgeoff)
I have seen the z10 (5 main, halo) one in person and it is beutiful!! Awesome people, awesome products... z10
Old Sep 18, 2003 | 05:14 PM
HXMan's Avatar
Whoops...reminds me of the d series girdle.
Old Sep 18, 2003 | 07:35 PM
Turbocivic94's Avatar
U cant just buy the girdle, there are other things involved in installing a girdle
Old Sep 18, 2003 | 07:39 PM
DaveF's Avatar
Default Re: Z10 Bedplate (Jamison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jamison &raquo;</TD></TR><TR><TD CLASS="quote">I have seen the z10 (5 main, halo) one in person and it is beutiful!! Awesome people, awesome products... z10 </TD></TR></TABLE>
hell yea, you can say that again.....
your bandwagon jumpin idiots can talk alot of smack about something, but not know a damn thing about it or have any experiance to back up your mouths.
go check out the Z10 5 main girdle in person with Halo ring and alll......talk to jim, he will set you straight.
Old Apr 1, 2004 | 08:43 PM
00siBuilder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Z10ROB &raquo;</TD></TR><TR><TD CLASS="quote">Endyns Girdle is not a 5 Main. Its a 3 Main COPY! of the Z10 3 MAIN
dont be mad because he improved on your design. Your being selfish and not looking at bettering the sport...
Old Apr 2, 2004 | 04:50 AM
tony1's Avatar
Default Re: Z10 Bedplate (00siBuilder)
Just out of curiosity, has anyone ever seen main bearing problems in a b block? I haven't. If it ain't broke...
Old Apr 2, 2004 | 09:25 AM
MackSpeed-616's Avatar
Default Re: Z10 Bedplate (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Just out of curiosity, has anyone ever seen main bearing problems in a b block? I haven't. If it ain't broke...</TD></TR></TABLE>
if it ain't broke, i'll fix it until it is!
but seriously, these things will just be more of a problem than stock if they dont fit right. i think we all remember the z10 3 bolt mains that didnt fit, unless you machined dowels into them.. like stock!
i personally ran an LS block w/o any type of main girdle at 9500rpm for an entire year and had no abnormal bearing wear or related problems in the block.
this personally seems to me like just another marketing scheme to make a buck. sure the new K blocks come with them stock.. but that is STOCK! I dont doubt the z10s may make the bottom end stiffer, but is that even neccesary??
Old Apr 2, 2004 | 09:33 AM
Unsung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00siBuilder &raquo;</TD></TR><TR><TD CLASS="quote">
dont be mad because he improved on your design. Your being selfish and not looking at bettering the sport... </TD></TR></TABLE>
^^ What he said. Z10 gets a huge thumbs down for his comment, badmouthing another business on a public web board, especially in a manner where Larry obviously improved your design.
Old Apr 2, 2004 | 09:41 AM
quickda6's Avatar
Default Re: Z10 Bedplate (Unsung EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsung EM1 &raquo;</TD></TR><TR><TD CLASS="quote"> Z10 gets a huge thumbs down for his comment, badmouthing another business on a public web board, especially in a manner where Larry obviously improved your design.</TD></TR></TABLE>
Saying something was a COPY is not badmouthing bro...He didnt say f@ck endyn for stealing our design or anything.
Old Apr 2, 2004 | 09:43 AM
Unsung's Avatar
Default Re: Z10 Bedplate (quickda6)
Yeah i guess you are right, but the big bold COPY! is what pissed me off. Everyone on HT tries to take low blows at Larry whenever they can, I usually just get infuriated when I see it.
