If clutch master cylinder is shot....
Old Sep 11, 2003 | 07:23 PM
ludelvr's Avatar
Default If clutch master cylinder is shot....
would it still move the clutch fork if you stepped on the clutch when fluid was in it?
Old Sep 11, 2003 | 07:30 PM
mmuller's Avatar
Mad Scientist
Default Re: If clutch master cylinder is shot.... (ludelvr)
it depends how bad it is
Old Sep 11, 2003 | 07:35 PM
ludelvr's Avatar
Default Re: If clutch master cylinder is shot.... (mmuller)
well, it's not overly soaked (the carpet) but I can feel that it's moist. Also, my car's symptorms are that the shifter won't go into gear at a dead stop, but occassionally I can get it in and once I can get it into gear (if I don't move anywhere) I can shift to all gears, but once I get moving, it's really hard to get it into gear again!! Funny thing is that from what I recall, there wasn't a huge loss in clutch fluid!
Old Sep 11, 2003 | 07:36 PM
mmuller's Avatar
Mad Scientist
i drove with a leaking master cyl. for a while.
just get a friend to push the pedal while you look at the shift fork move
Old Sep 11, 2003 | 07:51 PM
ludelvr's Avatar
we tried that when we were bleeding the clutch and he said it was moving. First of all, how far should normal travel be for it? Secondly, what else could it be?
Also, when your clutch MC was leaking, did you have the same problems as me and was your shift fork still moving?
Old Sep 12, 2003 | 04:15 AM
JimBlake's Avatar
Pump the clutch pedal repeatedly & see how far it goes. Maybe it'll go a bit farther each time you pump it. That can give you an idea how far it's supposed to go. Maybe someone with a good clutch can measure the motion for you. I wanna guess 3/4 inch, but it's been a while since I watched it, & I never actually measured it.
Then watch it while holding the pedal all the way to the floor. If the MC is bypassing, the fork will slowly return to its rest position, as if you were slowly lifting the pedal. This means it's internally leaking back into the reservoir.
Leakage along the piston rod into your carpeting isn't the same thing, it's just a mess & you're always losing fluid. But often the MC can have both problems.
Old Sep 12, 2003 | 04:20 AM
~~~InNeEdFoRsPeEd~~~'s Avatar
* B A N N E D *
well if it's leaking, just replace the darn thing $40 from junkyard
jdm_phunk
Feb 27, 2011 05:17 PM
hpimichael02
Oct 31, 2008 09:46 AM
lax1089
Jul 23, 2007 02:03 PM
koldkustoms
11
May 1, 2007 05:58 AM
reno96teg
Jul 12, 2005 08:07 PM
