What would cause my car to sound like its a Carbed '70 Chevelle...
Old Sep 11, 2003 | 04:16 PM
FourthGenHatch's Avatar
Default What would cause my car to sound like its a Carbed '70 Chevelle...
For some reason after school today when I was driving my car I noticed it sounded different. Over the drive home when at lower rpms and sometimes all the time it makes a gurgle gurgle sounds like its some carb'ed Muscle Car. I thought maybe my exhaust was loose and the sound is coming from the engine area so I tightend all those exhaust bolts but it still makes this weird sound. Anyone had this problem before.
I'm not throwing any codes and the car still drives fine it just sounds shitty.
Old Sep 11, 2003 | 06:54 PM
Default Re: What would cause my car to sound like its a Carbed '70 Chevelle... (FourthGenHatch)
bump
Old Sep 11, 2003 | 09:16 PM
Broken Gearbox's Avatar
header leak?
Old Sep 11, 2003 | 09:29 PM
STHPERFORMANCE's Avatar
Default Re: What would cause my car to sound like its a Carbed '70 Chevelle... (James.)
I would say a exhaust leak..............
Or a big cam was put in there when you werent looking
Old Sep 11, 2003 | 09:30 PM
4door_gsr_ftw's Avatar
I say a hole in your muffler.
Old Sep 12, 2003 | 02:48 AM
Is there an easy way to find the leak? My HKS exhaust I put more stock in than the Chikara header so I bet there is something with the header since the sound comes from the front anyway. I'll check into it.
Old Sep 12, 2003 | 03:21 AM
rjardy's Avatar
my old civic did this with a blown head gasket, and that was the only sign of the blown head gasket (other than low comp in#4)
Rob
Old Sep 12, 2003 | 06:46 AM
ceas's Avatar
Horsepower!
ceas..
Old Sep 12, 2003 | 11:30 AM
Jeff C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote"> Chikara header </TD></TR></TABLE>
Thats a 2 pc., correct? I'd check the gasket between the two halfs.
Old Sep 12, 2003 | 12:29 PM
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">Is there an easy way to find the leak? My HKS exhaust I put more stock in than the Chikara header so I bet there is something with the header since the sound comes from the front anyway. I'll check into it.</TD></TR></TABLE>
start up the car and take a cigarette lighter and put the flame around the joints of the exhaust. if theres a leak, the flame will flicker excessively.
Old Sep 12, 2003 | 04:00 PM
Default Re: What would cause my car to sound like its a Carbed '70 Chevelle... (keebler65)
I think I found it. It looks like a small crack on the #1 cylinder exit for the header.
Old Sep 12, 2003 | 04:10 PM
91civicEX's Avatar
and pray you dont have a fuel leak
Old Sep 12, 2003 | 05:28 PM
Why would I have a fuel leak?
There is what looks like a dent on the header with a ridge. I poked it but the metal is strong so thats not really going to do anything.
However it makes sense because the car was fine in the morning, than sounded funny after school. So when I went to school it must have been real hot and than cracked as it was cooling down when I was inside. So when I got out and started driving it it sounded funny.
I got some JB weld so that should do the job.
Old Sep 12, 2003 | 08:58 PM
andrew dc's Avatar
jb weld baby! that stuff does magic!
Old Sep 13, 2003 | 11:19 AM
Default Re: What would cause my car to sound like its a Carbed '70 Chevelle... (andrew ef)
Actually nevermind. It wasn't a crack, just a weird looking spot on the header. The leak is coming from the spot where the 2 connect. When I installed it I had to dremel off some of the header cuz it hits the ZC block. So when I did that I could never get the one bolt to screw in all the way. So it must have made it easy for the exhaust to leak out eventually. Its ok. I'll take the header off and I want to paint it with some high temp paint so it doesn't look so shitty. And I can either make my own gasket, or grind me of the header down so it clears right.
joytjuhhhh
Nov 17, 2014 02:24 AM
EG8AI
Jun 29, 2008 09:14 PM
92EG8
13
Mar 16, 2007 08:25 PM
sittingonROTAS
16
Jul 21, 2006 10:35 AM
Bklyn TSi
Jul 11, 2002 08:07 AM
