what do you think
normally when a cluch is going bad u will notice that it may take longer for it to fully engage, it will also start slipping on you (not grab as hard) it may also slip in the higher rpm, and sometimes it can cause your gears to grind a bit !!
I dont know how many miles are on you clutch and how much abuse it gets but if its a OEM clutch, with regular driving then it should last well over 100k !
Is it just me or do Excedy clutches suck ***? My oem clutch went out and i was broke at the time so i had to get something cheap...well the Excedy clutch i got is now starting to slip pretty bad. I knew it would suck before i put it in but i didnt think it would be this bad
Just say no to Excedy!!!!
Jaydeep
Oct 23, 2009 07:40 AM
wompwomp61
10
Feb 3, 2005 11:05 AM
