ATTN: What piston bore for street-turbo set-up?
Old Sep 11, 2003 | 10:31 AM
Fuzion's Avatar
Default ATTN: What piston bore for street-turbo set-up?
i see sum sleeved blocks for sale and they are 86.5mm and so on and sum 85mm and 86mm. What i wana know is, is that to thin of a cylinder wall to run a high boost turbo street set-up? Im talkin about 400-470whp 20-26psi or so. With that much boost and stress, even though they are aftermarket sleeves, will they hold up for a daily driver car. If they are strong enough then i can get a crazy bore lik 86mm or so, 86.5mm maybe? On low boost that will make alot fo power way more tq than those 83mm-84mm @ same psi.
Old Sep 11, 2003 | 11:47 AM
BLAP BLAP!!!
Guest
Posts: n/a
Default Re: ATTN: What piston bore for street-turbo set-up? (Fuzion)
it all depends on what kinda numbers you want to put down.. if a motor is tuned right and can handle the boost.. then it just matters how you treat your car.. take care of your ride and it takes car of you..
Old Sep 11, 2003 | 01:49 PM
SpoolnG2's Avatar
Default Re: ATTN: What piston bore for street-turbo set-up? (BLAP BLAP!!!)
i say stick with a 83mm bore, b/c if for say u do mess something up, u can rebore and your ready to go, u don't have to get whole new sleeves. also, with a little bit thicker sleeve, your a lot safer running high boost. if u wanted to do something "nutty" then just run higher compression pistons. that will give u more power instead of boring it to an unsafe size. u just have to make sure its tuned right. but really, with a 83mm bore...sc61 ..9:1 c/r...and 26psi, u will make a little over 500whp.
slammedobd1teg
Apr 16, 2009 05:38 AM
neiler3
Dec 11, 2008 10:32 AM
LSEGHATCH
Mar 14, 2005 05:28 PM
Nikoli
May 30, 2004 07:31 AM
VanHonda
Nov 9, 2003 06:42 PM
