b18c1 crx won't start (obd1)
Old Sep 11, 2003 | 09:31 AM
McDade's Avatar
Default b18c1 crx won't start (obd1)
https://honda-tech.com/zerothread?id=616286
Any help would be greatly appreciated
Old Sep 11, 2003 | 07:59 PM
JasterM5's Avatar
Default Re: b18c1 crx won't start (McDade)
bump
Please help guys, we're out of ideas
Old Sep 11, 2003 | 08:31 PM
TeStUdO's Avatar
Try switching ECU's. Is the car turning over at al?? No spark??? Still getting fuel?? How about the timing?? Firing order??
Old Sep 12, 2003 | 04:18 AM
JasterM5's Avatar
Default Re: (TeStUdO)
That's the problem, we dont hav another ecu to test with. Its definitly getting fuel because we can smell it when we take out a spark plug to test for spark. But thats just it, no spark at all. Also the ECU leaves the check engine light on steady. Does that mean the ECU is toast? Or could it be the distributor? Or maybe both? we just don't know, and its not like these parts are cheap.
Old Sep 12, 2003 | 06:20 AM
TeStUdO's Avatar
Well try checking the cap and rotor. I really think it might be the ECU, try to see if you can get one from the junkyard or from a friend to test it. If it wont even throw a code if you jump it then I think the ECU might be bad
Old Sep 12, 2003 | 06:31 AM
JasterM5's Avatar
oh yeah, we already bought a new cap and rotor for the distributor. But we thought the actual dizzy my be bad. Although at this point we're leaning towards the ECU.
Old Sep 12, 2003 | 07:17 AM
TeStUdO's Avatar
Default Re: (JasterM5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasterM5 &raquo;</TD></TR><TR><TD CLASS="quote">Although at this point we're leaning towards the ECU.</TD></TR></TABLE>
Im pretty sure that is it
Old Sep 12, 2003 | 12:39 PM
EFb18b's Avatar
you guys just went threw the entire troubleshooting tree in helms for this problem. You might want to try unplugging a couple sensors to see if the light goes out. If it does try replacing the sensor first before you go spending a couple hundred bucks on an ecu. just a thought...
Dancing is Forbidden
Feb 11, 2015 04:19 PM
chingo450r
Engine Management and Tuning
Mar 20, 2013 02:02 AM
ex_ricer
Aug 14, 2008 11:42 AM
fenix4o9
Jul 8, 2007 07:26 PM
McDade
Sep 15, 2003 10:19 AM
