Service required light on?
The service light is on in my girls car. I"m assuming this means that they want to charge me some ourtrageous amount of money to do a normal service? How do I turn this light off?
There is a small black box underneath the dash below the steering wheel. It has a small green button on it. Depress the green button and turn the key to acc on position. Keep holding until the light goes off and your good to go
Is it a maint req light or CEL? If its a maint req,then just reset the light, by holding the button under the steering column. If its a CEL,then you'll need to pull the code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 »</TD></TR><TR><TD CLASS="quote">Is it a maint req light or CEL? If its a maint req,then just reset the light, by holding the button under the steering column. If its a CEL,then you'll need to pull the code.</TD></TR></TABLE>
yep.....mine's a blue button though...
CleanShaven
Jan 23, 2005 10:16 AM
