oil leak with brand new motor
just install brand new R motor and i have a major oil leak near the cam gears. car runs perfect but major oil leakage near the cam gears i check everything and can not source out my problem. anybody have any thoughts on what it could be? new cam seals new valve cover gasket everything is new...the install has went perfect until this!
It may seal eventually - that's what my leaky head gasket did after my new block was installed. Where'd you get the motor from?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">check teh cam seals...easy fix.</TD></TR></TABLE>
the cam seal needs to be hondabond'd......so if that was not done that is why it is leaking.....if it is indeed from the cam area....
i finally realized what the problem was that i installed the cam seals the wrong way DUH!!! spring side should always point inside!!! thanks for the help!!
TealEG!
Aug 5, 2008 08:10 PM
EJ1 wilcox
Jan 14, 2007 07:54 PM
