Slight rust in cylinders
Old Sep 11, 2003 | 03:29 AM
Lsos's Avatar
Default Slight rust in cylinders
I started getting ready to put my head back on, and I noticed rust starting to develop towards the top inch of the cylinder walls
Should I scotch-brite them? Can I just wipe them down and call it a day? Should I just pretend I never saw anything?
Or, do I have to rehone the cylinders or something terrible like that?
Old Sep 11, 2003 | 05:30 AM
LudeyKrus's Avatar
Default Re: Slight rust in cylinders (Lsos)
have the cylinders been honed?
Old Sep 11, 2003 | 05:59 AM
Lsos's Avatar
Default Re: Slight rust in cylinders (LudeyKrus)
I just took the head off a factory motor, got it rebuilt, and want to put it back on. I didn't touch the bottom end.
Old Sep 11, 2003 | 06:08 AM
Fkned2003's Avatar
It would depend on the amount and penetration of the rust.If it's surface rust and wipes away with wd40 and very fine scotch brite go ahead and put the head on .But if it doesn't clear up you'll have to get a slight hone.
Old Sep 11, 2003 | 08:22 AM
BeerMan's Avatar
Default Re: Slight rust in cylinders (Fkned2003)
Try cleaning it up with wd40, as suggested above. Get the cylinders honed anyway. I would think the rust would come off. But, if it is really bad, have the cylinders overbored and use overbored pistons.
Old Sep 11, 2003 | 08:42 AM
Lsos's Avatar
Default Re: Slight rust in cylinders (BeerMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeerMan &raquo;</TD></TR><TR><TD CLASS="quote">Try cleaning it up with wd40, as suggested above. Get the cylinders honed anyway. I would think the rust would come off. But, if it is really bad, have the cylinders overbored and use overbored pistons. </TD></TR></TABLE>
That's the thing, I just wanted to fix my head. I was hoping to avoid touching the bottom end....getting the cylinders honed is not something that will take a couple minutes...
I guess I'll try the WD-40 and see how it looks. If there's still a crosshatch pattern I'll just grab a and call it a day. If not, then I'll be pissed.
Old Sep 11, 2003 | 09:49 AM
LudeyKrus's Avatar
is it above where the rings will go to?
Old Sep 11, 2003 | 10:39 AM
Lsos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">is it above where the rings will go to?</TD></TR></TABLE>
No. The rings would touch the rust if I was to turn the motor.
Old Sep 11, 2003 | 01:49 PM
Aceman64's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeerMan &raquo;</TD></TR><TR><TD CLASS="quote">But, if it is really bad, have the cylinders overbored and use overbored pistons. </TD></TR></TABLE>
The guy just got his head redone. I'm sure there isnt any deep rust that would require all that. Maybe if he had the car outside in the rain with the hood open for a few weeks?
Get some emery cloth and clean then up with that.
-Ace
Old Sep 11, 2003 | 03:34 PM
Tachibana's Avatar
Did you leave the metal exposed to open air? If it stays exposed to open air/elements, surface rust will eventually form, especially if it was just re-honed/bored. I'd say just clean it with solvent, or apply a thin coat of motor oil, and carry on.
If its deep rust, then you got a problem.
Old Sep 12, 2003 | 04:48 AM
Lsos's Avatar
Default Re: (Tachibana)
I coated everything with oil and put a paper towel over it, then closed the hood. Maybe I didn't actually coat it with oil but just think I did
Natural Aspirations
Apr 7, 2013 07:11 PM
colnago
Mar 9, 2007 07:49 AM
SPOOLINmatt
May 8, 2006 05:07 PM
310BHPB16
Aug 26, 2005 07:59 PM
DC2R714
Apr 27, 2003 06:25 PM
