keyless entry module in head unit?
Old Sep 10, 2003 | 01:58 PM
baphomet's Avatar
Default keyless entry module in head unit?
I want to replace my factory head unit on my 99 si with an aftermarket one, but I read somewhere that the keyless entry is integrated with it, is this true?
Old Sep 10, 2003 | 02:01 PM
baphomet's Avatar
Default Re: keyless entry module in head unit? (b3435)
would this apply to me as well https://honda-tech.com/zerothread?id=446028
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">if you leave the stock radio there, it will not function at all, besides power up. you can get the harnesses necessary at best buy or circut city. when you go there you need to ask for a harness for your car and the reverse harness. at best buy we take the radio and push it in the dash behind where the electrical outlet is. once you get the car apart youll see it. it does take some time to get it in there right though. all you need to do to keep your keyless is make sure your deck gets power as it normally would, other thant that hook up your new radio as normal.</TD></TR></TABLE>
Old Sep 11, 2003 | 05:50 AM
baphomet's Avatar
anyone want to confirm this for me, thats all I ask
Old Sep 11, 2003 | 06:16 AM
carolinaACCORD's Avatar
Yes, you will need to keep your factory head unit behind the dash.
All wiring harness manufacturers sell a "Y" harness to do this. I know the Metra part # is 70-1720T.
Old Sep 11, 2003 | 07:50 AM
PHiZ's Avatar
Default Re: keyless entry module in head unit? (carolinaACCORD)
Wow, seriously, that is ******* bogus!@
-PHiZ
Old Sep 11, 2003 | 10:56 AM
baphomet's Avatar
Thanks!
Old Sep 11, 2003 | 11:24 AM
B18C_EJ8's Avatar
If you don't want to wait for your shop to order the Metra "Y" harness, you can get the Metra 70-1721 and 71-1721 harnesses and wire them up with your new deck... Allows the new deck to plug in, and lets the relocated deck plug in too.
Old Sep 11, 2003 | 11:57 AM
baphomet's Avatar
Default Re: (B18C_EJ8)
I do my own installs - I wonder if cruchfield has the Y harness.
Old Sep 12, 2003 | 01:53 PM
PupaScoopa's Avatar
Default Re: (b3435)
I pulled my OEM HU and my keyless entry still works (99 Si). Go figure...
Old Sep 12, 2003 | 05:23 PM
jonyb's Avatar
I thought they stopped integrating the keyless after 1998. 96-98 cars were like that for sure though.
Unplug the radio and try the keyless. It'll take about 5 minutes. Then you'll know for sure
Old Sep 12, 2003 | 05:44 PM
jdmotorsports's Avatar
Default Re: (jonyb)
99+ should not do this anymore. unless you have a realy early 99 it shouldnt be in the head. the best way to check is if there is a box ontop of the headunit that looks like it comes out.
Old Sep 12, 2003 | 05:45 PM
97EXB18C's Avatar
This is correct. Had the same issue with my 97ex. Just installed an alarm that worked the locks, problem solved and I got an alarm
GJWilliamson
Jul 11, 2007 11:57 AM
tlkolrod
Audio / Security / Video
Nov 15, 2006 08:03 AM
cbmprelude
13
Aug 2, 2006 04:05 AM
Scott99
Mar 11, 2006 09:13 AM
mamaboy
20
Apr 11, 2003 07:23 PM
