How do you adjust JDM HID headlights?
Old Sep 10, 2003 | 11:46 AM
SpoonSpecR's Avatar
Default How do you adjust JDM HID headlights?
Beampattern for Lowbeam...? I can't get a tool down into the location- am in the right area? I see a small bracket with curved arrows that says Up and Down. There are two 3/8" nuts next to it- Is this it? Or is it this funky small nut with a cookie cutter style washer?
Thank you fellow JDM'ers
Old Sep 10, 2003 | 12:29 PM
98R-1144's Avatar
Default Re: How do you adjust JDM HID headlights? (SpoonSpecR)
no those aren't the screws...it's kinda like a little wheel with teeth..it's located slightly below that black black bracket... its kind of in the middle of the headlight (heightwise).
i guess i'ts hard to explain.. but a standard phillips screwdriver should fit fine in both areas
i would post pics if i had some
Old Sep 10, 2003 | 01:41 PM
SpoonSpecR's Avatar
Default Re: How do you adjust JDM HID headlights? (98R-1144)
Is it below the two 3/8" bolts? How do I measure the height? Is their a formula, like from 10 feet away from a wall...?
Old Sep 10, 2003 | 09:45 PM
PYMUGENITR's Avatar
Just adjust the dial with the headlights on, its extremely easy. I believe its a 5/16".
Old Sep 11, 2003 | 12:59 PM
SpoonSpecR's Avatar
Default Re: How do you adjust JDM HID headlights? (PYMUGENITR)
I adjusted them but holy moley- way too high! Whats a good rule of thumb?
Old Sep 11, 2003 | 02:09 PM
PYMUGENITR's Avatar
Park 10feet in front on a flat surface. Adjust the beam pattern so it is level/slightly lower than your headlights. (i.e.) you want your headlights nearly parallel to the groud.
Old Sep 16, 2007 | 12:32 PM
JDM_wanna_Be's Avatar
So which bolt was it? I can't seem to find the bolt.
Old Sep 16, 2007 | 12:40 PM
JjuuN R's Avatar
Default Re: How do you adjust JDM HID headlights? (JDM_wanna_Be)
Old Sep 16, 2007 | 04:56 PM
an2ny888's Avatar
Default Re: How do you adjust JDM HID headlights? (JjuuN R)
a bit ot.. how do you guys like the jdm itr hid's? how's the light output, considering the right hand drive beam cutoff
Old Sep 16, 2007 | 05:11 PM
Spids5's Avatar
Don't judge or question
Default Re: How do you adjust JDM HID headlights? (an2ny888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">a bit ot.. how do you guys like the jdm itr hid's? how's the light output, considering the right hand drive beam cutoff</TD></TR></TABLE>
I love mine and I don't think I would ever buy another car with HID headlights. Btw I have a set for sale if you are looking to upgrade.
Old Sep 17, 2007 | 06:21 AM
jetblackhybrid's Avatar
i LOVE mine! they have the cleanest cut-off and most even spred i have seen. worth every penny!
86belated
Jul 27, 2012 05:38 AM
lickety_britches
Aug 29, 2010 10:07 PM
VTECdohcter
Jun 15, 2008 10:17 AM
SilverDc2
Dec 26, 2003 09:12 PM
