B16 Bogg help.
Old Sep 10, 2003 | 10:14 AM
UNDER PRESSURE's Avatar
Default B16 Bogg help.
O.K. here's the deal I have a '89 crx si w/ a B16a and turbo. My problem is that every time I stab the throttle it boggs bad and all of a sudden accelerates like a bat out of hell. So I put it to the test by giving it gas gradually and guess what, when I do that it accelerates fine and there is no sign of bogging what so ever. Can you fellas help me in diagnosing the problem. Oh yeah the car has been tuned.
Old Sep 10, 2003 | 11:26 AM
Mr Furball's Avatar
Default Re: B16 Bogg help. (UNDER PRESSURE)
Is that just turbo lag? Not to good with turbo's but that's my guess.
Old Sep 10, 2003 | 11:38 AM
Doctor CorteZ's Avatar
what turbo do you run ?
Old Sep 10, 2003 | 12:31 PM
Phatwhippin_CRX's Avatar
Default Re: B16 Bogg help. (Doctor CorteZ)
check your dizzy and if you have a cat, that too...
Old Sep 10, 2003 | 12:38 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Default Re: B16 Bogg help. (Phatwhippin_CRX)
I had similar symptons a few monthes back, I had a coolant leak in my lower radiator hose. Replaced it and the stopped. Are you leaking coolant?
Old Sep 10, 2003 | 12:54 PM
Default Re: B16 Bogg help. (SeaBass)
I'm running the greddy single cam turbo on a B16.
Good **** seabass. I haven't checked for water leaks but now that you mention it awhile back my car started leaking water from a water line that had been plugged, and I did notice that the car was running a little wierd. I put a new plug on it but I don't know if the line is suppost to run anywhere The water line is right under the intake manifold. Any guesses were that water should be routed to instead of just being plugged?
Old Sep 10, 2003 | 02:14 PM
civickiller's Avatar
same thing happened to me, put some fuel injection cleaner adn a new fuel filter, fixed it right up
Old Sep 10, 2003 | 02:53 PM
Default Re: B16 Bogg help. (civickiller)
You know that's the only thing I haven't tried i'll do that tonight.
Old Sep 10, 2003 | 03:03 PM
Stupid Ass's Avatar
Fuel Filter... o2 sensor or spark plugs or dizzy.
Old Sep 10, 2003 | 03:52 PM
Default Re: B16 Bogg help. (MooreVTEC)
Thanx for narrowing it down for me.
powerdbygarrett
Jun 29, 2009 04:45 AM
smokerz212
Nov 12, 2006 11:25 AM
Samuels
Jun 30, 2006 11:01 AM
spoonhatchblack
13
Sep 27, 2005 04:12 AM
