car won't start after tubo install
Old Sep 9, 2003 | 08:38 PM
crxY-49's Avatar
Default car won't start after tubo install
I don't know what the problem is. I started the car up fine with 450's and the safc installed, then i threw my turbo on and it won't start. Could it be because I cranked it over so much without the plug wires in to circulate oil through the turbo? How long would it take for my car to start if the motor is flooded? thanks.
Old Sep 9, 2003 | 08:42 PM
inspyral's Avatar
So you didn't pull the FI/EM fuse to cut the fuel? If it's flooded, pull that fuse and turn it over a few times with your plugs out to try and get the excess fuel out.
Old Sep 9, 2003 | 09:01 PM
crxY-49's Avatar
Default Re: (inspyral)
i think i need new plugs. What type should i get and how much should i gap em? the motor is a d16a6 with a 14b turbo. thanks
Old Sep 10, 2003 | 12:44 AM
rjardy's Avatar
Default Re: (crxY-49)
It should still start with the old plugs. I think that it is more than likely flooded. Just yank the fuse to the pump and crank it for a good 7 seconds then let it rest. Do that 2 or 3 times, then it should start up.
Rob
jdm201010
Mar 18, 2014 11:51 AM
free99
Mar 18, 2008 10:52 AM
krazyDOHC
May 28, 2003 07:10 AM
