Another COMTECH header question... but for a B16!!
Old Sep 9, 2003 | 05:37 PM
Irishweird00's Avatar
Banned
Default Another COMTECH header question... but for a B16!!
Planned setup for my b16a2
hondata
310 injectors
Skunk 2 stage 3's
Skunk 2 dual valve springs
Skunk 2 titanium Retainers
Skunk 2 cam gears
J's racing Carbon intake
Aebs Intake manifold
P&P head
3 angle valve job
Endyn High compression pistons
Probe/Eagle rods
Balancing the bottem end
for starters....
But i need a good exhaust system, and I was looking at the 4-2-1 TIG welded Comptech race header...... But im not sure if it right for my planned setup.
Anyone care to comment? on anything?
Old Sep 9, 2003 | 06:28 PM
chris@allmotor.net's Avatar
Default Re: Another COMTECH header question... but for a B16!! (Irishweird00)
never heard of a comtech header
Old Sep 9, 2003 | 06:34 PM
Banned
Default Re: Another COMTECH header question... but for a B16!! (chris@allmotor.net)
oh boy.... forgot the P...
Old Sep 9, 2003 | 06:35 PM
Eyewitness's Avatar
Comptech
Old Sep 9, 2003 | 07:33 PM
Banned
Default Re: Another COMTECH header question... but for a B16!! (Eyewitness)
anyone know where i can actually get the RACE header... not the SS...
Old Sep 9, 2003 | 07:35 PM
vtecvoodoo's Avatar
Future Texas Boy
e-mail nateh@comptechusa.com
ShineStreet can get you one, or I can.
Old Sep 9, 2003 | 07:37 PM
Banned
Default Re: Another COMTECH header question... but for a B16!! (vtecvoodoo)
i still havnt found a price on one, what am I in for?
Old Sep 9, 2003 | 07:42 PM
vtecvoodoo's Avatar
Future Texas Boy
Full Race Header will run you at least $850.
Old Sep 9, 2003 | 07:43 PM
1fasthb's Avatar
go with dtr header its real nice and you will be happy with the power gains
Old Sep 9, 2003 | 07:48 PM
Banned
I looked at the smsp headers, but 1g on a header is to much for my pocket... I'm looking for a good all motor 4-1 header... but i know i get what i pay for... and im not going to buy a cheap *** dc header...
voodoo, any suggestions?
Old Sep 9, 2003 | 07:51 PM
vtecvoodoo's Avatar
Future Texas Boy
Header Tech.
Old Sep 9, 2003 | 07:58 PM
1fasthb's Avatar
http://www.dtrfab.com
Old Sep 9, 2003 | 08:00 PM
Banned
Default Re: Another COMTECH header question... but for a B16!! (1fasthb)
the Header Tech SS 4-1 is around 500 isnt it? or is it more
Old Sep 16, 2003 | 07:29 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irishweird00 &raquo;</TD></TR><TR><TD CLASS="quote">but 1g on a header is to much for my pocket</TD></TR></TABLE>
Whether $1000 is too much for a header depends on what you are getting for $1000. If, for instance, a DTR header ($1050 for stainless) really can get you 10-13HP over a JDM ITR 4-1 header (more if you are upgrading from a cast manifold), then I would say that it is well worth $1000. What else can you do for $1000 that is so easy to do and is going to get you a solid 10-13HP at the wheels untuned? And even if you DO end up doing other mods instead, you will reach a point where it becomes increasingly difficult to gain more power. If you get to this point, you might wish you had spent the extra cash for a better header.
Old Sep 16, 2003 | 09:11 PM
99-DC2's Avatar
If you want to save a lot, just get the ITR 4-1 header.Also get skunk2 stage2 cams if you want a street car. Stage3 is not a very streetable cam.
Old Sep 16, 2003 | 09:25 PM
AllmotorJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fasthb &raquo;</TD></TR><TR><TD CLASS="quote">go with dtr header its real nice and you will be happy with the power gains </TD></TR></TABLE>
Just ordered mine today! I saw the OTS 2000 and its great. Talked with Danny for awhile too. He's a kool cat!
Old Sep 17, 2003 | 06:54 AM
BERT-O's Avatar
Pics of the Comptech Race header
Old Sep 17, 2003 | 11:03 AM
slofu's Avatar
i'm also going to try the comptech race header, but honestly, i'd be afraid to use it on a street driven car with a b16a unless you mounted the engine higher, since the ground clearance will be 7mm lower with the b16a than with the b18/b20, due to the shorter deck height. this is more of a problem if local roads are rough, or if your car is lowered. also, the long 4-2-1 tri-y designs pairing sequentially firing cyls (1-3, 4-2 or 1-2, 3-4) are generally made to work better with engines having lower rod:stroke ratios, partially due to their cylinder pairing, and partially due to their piping diameters and lengths. i'd call header tech or dtr, give them your specs and applications, and have enzo or danny make you a nice custom piece for a fair price. it'll prolly cost the same or less, and work better for you.
Old Sep 17, 2003 | 11:45 AM
BERT-O's Avatar
Default Re: Another COMTECH header question... but for a B16!! (slofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slofu &raquo;</TD></TR><TR><TD CLASS="quote">i'm also going to try the comptech race header, but honestly, i'd be afraid to use it on a street driven car with a b16a unless you mounted the engine higher, since the ground clearance will be 7mm lower with the b16a than with the b18/b20, due to the shorter deck height. this is more of a problem if local roads are rough, or if your car is lowered. also, the long 4-2-1 tri-y designs pairing sequentially firing cyls (1-3, 4-2 or 1-2, 3-4) are generally made to work better with engines having lower rod:stroke ratios, partially due to their cylinder pairing, and partially due to their piping diameters and lengths. i'd call header tech or dtr, give them your specs and applications, and have enzo or danny make you a nice custom piece for a fair price. it'll prolly cost the same or less, and work better for you. </TD></TR></TABLE>
hey,
PM me,
Bert
Old Sep 17, 2003 | 12:16 PM
RPM's Avatar
RPM
Here are some pics of the race header and race exhaust installed on a 98'ITR.
https://honda-tech.com/zerothread?id=542382
SD1222
11
Apr 26, 2005 04:53 PM
rough_draft
Jan 16, 2005 01:17 AM
sdpuck
Oct 1, 2004 07:43 AM
TypeR_Turbo
Jun 28, 2004 11:47 AM
justmotor13
May 8, 2003 04:14 PM
